Question about LG Heating & Cooling
I have an LG ducted air conditioner and have an CH32 error. Can anyone tell me what this is? Thanks
  • 2,133 Answers
CH-32 compressor discharge temperature too high. If over 105°C, check refrigerant charge.
Check and rectify the followings:
If over charged-release some gas./If less rpm of fan motor-replace capacitor./Condenser block-Clean it.
Posted on Jan 02, 2011
I have a new LG ducted AC unit B62UWYUY81 and geeting error code CH 54 on the remote controller . Can you help to reset the system.
Reverse or open phase. Check all 3 phases are present and correct. If correct voltage appears at all three phases, swap any two to cure the fault. Thanks. Helpful?
Feb 11, 2011 | LG Heating & Cooling
Can anyone tell me what error code E 05 means?
Please always write your problem with brand name/model/type/btu which will help you to get quick solution.
If Lg make air conditioner,
Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
If other units,
E5 Outdoor activation of compressor over heatprotection or motor lock.If fan motor struck, replace fan motor. If condenser not cleaned, clean it. Thanks.
Feb 06, 2011 | Heating & Cooling
I have an error code of E3 on my ducted air conditioner system. It is Starway - Does anyone know what the error means?
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Mar 14, 2010 | Heating & Cooling
Lg Ducted inverter airconditoning with error code COMPRESSOR SAFETY LP what does this mean?
The LP code is low pressure check to see if the air filter is clean if the filter is dirty this will restrict the air flow other wise you will need a service tech to check the refrigerant charge on your unit.
Jan 27, 2010 | LG Heating & Cooling
LO error code LG ducted
In my lg ac it automatically shut downs and restarts and lo is written in stead of temp what is the problem and what should i do?
Nov 20, 2009 | LG Heating & Cooling
Does anyone know if a Duo Therm model 620515.331c is ducted or not???
The upper unit itself is not ducted. They are all the same. The ducting is done with the lower unit or "Ceiling Pack" of the air conditioner. You need to see your RV is ducted, ie...vents in the ceiling that blow the are out. Usually they are round and mount into the ceiling. Another way to tell is if the unit has a wall mounted thermostat.
Hope this helps,
Jeff
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
LG error CH 64
What is the model of the unit?
Apr 07, 2009 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
741 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
