Cant install my dell 720 printer to my computer
  • 77 Answers
SOURCE: unable to communicate error
I have to make some assumptions here, let me know if I'm wrong. I assume you're using Windows Xp (Pro or Home). If so, disconnect the printer from the computer. Go to the Control Panel/Add Remove Programs. Uninstall the Dell printer. Go to the Control Panel/Printers and Faxes On Menu bar, click on File come down to Server Properties. in box that pops up click on Drivers/ Click on the Dell printer, click on Remove. Go to: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_INKJET_720&os=WW1&osl=en&catid=&impid= Download the latest driver for your Operating System to a location on your computer so that you know where to find it. Reboot your computer. Go to the downloaded driver. Double click on it. Follow the directions on the screen. It will let you know when you need to connect the printer to the computer again. That SHOULD do it. If it does not, please let me know before you rate this solution. I will try to provide additional information. Ed
Posted on Jun 28, 2007
IB4G2008
  • 3587 Answers
SOURCE: free download Dell printer 720 for Mac
yes...go to support.dell.com and see if your Imac is supported in the drivers section
Posted on Apr 28, 2008
john_yap
  • 51 Answers
SOURCE: Can you help me install my dell 720 printer with
you can follow these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
12. Make sure the driver you downloaded from support.dell.com is compatible with the operating system that you're using, for example windows xp or windows vista.
Posted on Oct 01, 2009
Nomodo4u
  • 863 Answers
SOURCE: My dell 720 printer has a new ink cartridge, acts
Take the plastic strip off the ink jet cartridge before putting the thing in the printer.  Check the ink jets to see if they are clogged.
Posted on Oct 25, 2009
Baloney King
  • 38 Answers
SOURCE: computer cannot communicate with printer Dell 720
when you print, make sure you have the printer set to "Dell 720".
Posted on Jul 26, 2010
Dell 720 printer not spooling
printers download the data in bursts from a memory stored in the computer
this spooling of tasks allows a single printer to print the next job and not mix up jobs as they are entered for printing
for this to work you have to install the driver for the printer into the computer and set printer priorities from other print sources
Nov 26, 2015 | Dell Inkjet 720 Printer
Just bought a new computer and my Dell 720printer does not work? Thank you
If you bought a new computer it probably has Windows 7 installed and the Dell 720 may not be compatible. You can try downloading the Vista drivers from Dell here. They may work with Windows 7. If not, you'll need to replace the printer with a later, Windows 7 compatible one.
Jan 09, 2011 | Dell Inkjet 720 Printer
Cant get my 720 printer to install on windows 7. No drivers available
hi you can use windows vista drivers for this printer to install on windows 7, have been to the dell website and they say, it is not compatible with windows7, but, the windows vista drivers will work..supplied is a link to this section, look at the bottom of the list where it says "operating system compatibility with dell printers" hope this helps..please vote thanks...click link below... http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=ans&k=720+printer+driver&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=tab
Aug 18, 2010 | Dell Inkjet 720 Printer
How do I install a Dell 720 computer on my Mac
Go to the support.dell.com site and locate the driver for that printer and download the MAC version. Run it per your normal install.
Apr 01, 2010 | Office Equipment & Supplies
Printer is not printing. The cartridges are full.
Did you try to install the drivers again? This may be the problem. try the following link- http://drivers.softpedia.com/get/PRINTER/OTHERS/Dell-Inkjet-Printer-720.shtml this should help to install a new driver on your computer.
Apr 06, 2009 | Dell Inkjet 720 Printer
Loading Software
install the printer driver first (do not connect the printer yet until installation procedure asks you to connect the printer)
then set it as your primary printer
Nov 04, 2008 | Dell Inkjet 720 Printer
Free download Dell printer 720 for Mac
Apr 28, 2008 | Office Equipment & Supplies
Software for dell 720
Go to Google.com and search for "dell 720 software download" (and take your pick)
Mar 17, 2008 | Dell Inkjet 720 Printer
18 people viewed this question
k24674
