Question about Lexmark Wheelwriter 1500 Typewriter
I have a Lexmark 1000 Personal Wheelwriter and the daisy wheel does not easily slide into place. It then just keeps turning until the machine beeps and it stops. Will not type of course. Is there a different daisy wheel for the Lexmark verses the IBM where the daisy wheel looks almost identical but it isn't?
  • 73 Answers
No, the printwheels are the same for all Wheelwriters. Make sure the letters face the roller when you put it in (pull the print hammer assy back and check for paper clips, ribbon pieces, etc. first).
Posted on Jan 02, 2011
Testimonial: "Thanks, it helps to know it is not the incorrect daisy wheel, I tried two and they both had to me kind of forced into the slot. Did not see anything b"
  • Charles Theile
    Charles Theile Jan 05, 2011
    Just a reminder that the hammer assy has to be pulled back to install the printwheel. Grab the black, grooved area and pull back against the spring tension before you try to put it in.
  • swooll Jan 05, 2011
    Thanks, I did, I used to sell these so I know a little, but the wheel is real tight going in. It's as thought teh actual metal slot got squashed or something, bent maybe? Not sure how this could have happened, thought it was a bad daisy wheel where the housing was not completely solid, but it is. Will check again, thanks for the extra hint.
Why does my wheelwriter 1000 lexmark typewriter makes this hummin sound as though its stuke.
Lube the round chrome rod that goes throught the carrier, Carier is what hold the ribbons and daisy wheel.
Lube pulleys on the belt. You may need to lube the carriage return motor too.
Aug 21, 2014 | Lexmark Wheelwriter 1000 Typewriter
After typing on a line and i hit return it stops wherever it wants
Clean and lube pulleys, and the silver round bar that goes throught the carrier. Carrier is what hold the ribbons and Daisy wheel. Its gummy and dirty.
Apr 10, 2014 | Lexmark Wheelwriter 1000 Typewriter
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps twice and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is...
Probably the key board is bad you can try my tip under WW 1000 or contact Geo. Beters Co.
@ 800-392-8085 for a key board rebuild. Tell them O'Reilly sent you.
DickyO
Apr 07, 2011 | IBM Wheelwriter 30 Typewriter
Personal Wheelwriter, the daisy wheel spins the carrier spaces to the right then it beeps..it keeps doing this til lit hits the right margin. tried anothe print wheel, no change.
It's not completing the power on reset probably a board or power supply. If you have the ability remove the board and look for debris on and around it.
DickyO
Oct 01, 2010 | IBM Wheelwriter 30 Typewriter
Can the Lexmark 1000 scan to PDF?
The only thing a WW1000 can do other than type is be a daisy wheel printer with an interface.
DickyO
Sep 03, 2010 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 10 Series II beeps
either the carriage home position sensor flag is broken or the daisy wheel can't find home. try removing daisy wheel and re-installit. turn unit on and see if daisy wheel spins if it does then the carriage home position sensor has a problem.
Nov 13, 2009 | Lexmark Wheelwriter 10 Series II...
Want Typewriter Look For Novel... But Still Use My computer
There were many typewriters made that could be used as a printer using a generic daisy wheel printer driver. Most of the IBM Wheelwriter with printer option or you may be able to find a daisy wheel mprinter on ebay.DickyO
Dec 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000 (IBM) beeping
You may have the R. margin there. Space all the way to the right, press R MAR key. You also could have spellcheck on code 1 will turn it off
Jan 28, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000
there should be 4 led lights on the right side of keyboard. what is the flash pattern?
Aug 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
The cartrdge won't move
? Cartridge..Do you mean ribbon cartridge, print Wheel, or Printer Ass'y. Also check line space LED's for error codes. Clean the sensor located on the printer ass'y (located behind the print wheel) with air. Also (power off) make sure the printer ass'y can slide freeley (L-R-L)and no obstructions have fallen into it's path. There is also a printer home position sensor located on the far left bottom of the printer ass'y travel path. Also clean with air. Let me know if you have error codes.
Mar 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
