Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
  • 335 Answers
If this is a usb problem, then the usb ports will not recognize any devices. Try testing the usb port with a flash drive, or a usb mouse (if you are already using a usb mouse, then usb is okay). Try to plug the hard drive into the port used by the mouse.
Another thing to do is to try the external drive on a different pc.
If the hard drive works on another pc then it is a usb port issue (see procedure below)
If the hard drive will not respond on another pc, then the drive housing is probably bad, and you can move the hard drive to another drive housing. usb drive housings are not expensive ($20-40).
If the drive works on another pc (and you are not using a usb mouse), try these steps:
right click 'computer' (my computer in xp) and left-click properties.
xp - click hardware tab at the top, then click device manager.
vista/7 - click 'device manager at top left of window.
Now you are looking at device manager, which represents the hardware (parts) of your pc. At the bottom of this window, you will see 'universal serial bus controllers'. Click the plus sign (or triangle) to expand this section of device manager. Now, starting at the bottom of the list, right-click on each 'usb root hub' and left-click 'uninstall'. work your way up from the bottom, deleting each usb root hub. Once you have done this, windows will probably start to re-detect and reinstall the usb root hubs (usb ports). If windows does not start to detect and reinstall them automatically, then reboot the pc and this will happen upon reboot. This procedure will often fix non-responding usb ports.
If you are using a usb mouse, and you try this procedure, you will lose your mouse at some point since it is a usb device (and we are deleting usb ports). If this happens, use the power button on the pc to reboot. Don't worry, the usb mouse will come back after the pc reboots and the usb ports are re-detected.
Please let me know how you make out.
Hope this helps!
Regards,
Joe
Posted on Jan 02, 2011
    Guru:
  • 825 Answers
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
My portable Drive is not working. Cannot be recognized when connect to the computer through USB port
The usual problem is the Drive enclosure. Take the drive out of the enclosure and fit into a new one. They are cheap and this will tell you if the drive has failed or not.
Apr 12, 2013 | Verbatim 320GB USB Portable Hard Drive
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
My fantom hd tfd500u16 is no longer recognized by my computer. I get a blue light and I hear the hd spinning. I uninstalled/reinstalled the drivers, replaced usb cord and tried connecting to other...
Is this an inbuilt drive or an external drive? If you're using USB, it needs a USB connection. It shouldn't need drivers as the computer will automatically detect a hard drive.
Have you tried connecting to a completely different computer to see if that recognised it?
Dec 30, 2010 | Fantom Titanium Hard Drive
HARD DRIVE CLICKS AND WHEN PUT IN A EXTERNAL ENCLOSURE DOES NOT GET RECOGNIZED BY OTHER COMPUTER.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 11, 2010 | Samsung SpinPoint P120S (SP2004C) 200 GB...
I have 500GB Roco (Toshiba) external hard drive... It was not dropped or physically damaged. My desktop and my laptop don't recognized it anymore. What seems to be the problem and how can i fix...
* the USB cable
* the power-adapter
Nov 10, 2010 | Toshiba 120GB USB 2.0 Portable External...
I've inserted PC/system hard drive into enclosure and connected by USB port to my stand-alone computer . . .How do I recognize or where do I find the menu to allow me to access the attachment/enclosure...
You do not have to do anything out of the ordinary for it to recognise. Connect the USB cable to the PC. If the hard drive is above 250Gb in capacity, connect the external power supply to it. Turn on any switc/buttons in the casing. Your PC should detect it as a Mass Storage device or as a regular hard disk.
Nov 22, 2009 | NexxTech 2.5" Hard Drive Enclosure
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
I have a Plumax enclosure I am trying to use. When I hook up my WD800 ide drive nothing seems to work. The power comes on, and the HDrive spins but my vista 64 desktop does not recognize or show the drive...
Try hooking it up to a different USB port. Go to computer on the start menu and see if your computer sees it. Try restarting your computer with the hard drive already connected and turned on, the computer may recognize it then.
Aug 23, 2009 | Plumax PM-350SI-PJS SIlver 3.5" Combo...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
111 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
