Question about Microwave Ovens
GE Profile Spacemaker XL Microwave: - Model No. JVM1330BW 002 - Serial No. HR900901S When I choose an Epress Cook# & press Start, the word Pause shows on the display panel. When I press Start again, I notice a microwave image on the display panel & the inside of the microwave image is blinking. The door is completely shut, but the microwave doesn't turn on / run. What does this mean?? I've unplugged the microwave in hopes of re-setting it, but it didn't solve the problem. How do I clear pause or delay start in case these features were set accidentally? Could not find any info on GE website...PLEASE HELP > Thanks
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
dmftrucker
  • 1922 Answers
SOURCE: GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Posted on Oct 02, 2009
jsrock516
  • 5911 Answers
SOURCE: The door handle on my GE Spacemaker XL model
If the outer door is not broken. All you have to do is replace the handle. You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. The part number for the door handle is WB15X10020. If the outer panel is damaged, you may have to replace the entire door. The part number is WB55X991. The cheapest web source I have found the handle listed is appliancepartspros.com for $47. The entire door, however, sells for $110 at pcappliancerepair.com.
The RF inside the cavity of a microwave oven is actually controlled by the RF shield in the glass. As long as the glass is intact and the inner door facing is not bowed, warped or cracked, you will not have to worry about RF leakage (even with the handle broken off).
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Nov 03, 2009
Testimonial: "A great resource"
SOURCE: where can I buy the handle of GE Spacemaker microwave?
amazon.com
Posted on Jan 04, 2010
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
How do I set the power at 50%?
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
Mar 20, 2015 | GE Profile Spacemaker XL 1800 36"...
G.E. profile Spacemaker XL1800 over the range microwave. the microwave comes on but dose not make anything hot. what is the fix & where is the replacement part located ?
We would need the full model number and we would need a little more information.
Please repost here with that information, and let us know - when you press "Start" to cook - if the inside light, turntable, and internal cooling fan all come on.
Nov 28, 2012 | GE Microwave Ovens
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven JVM1440 Two weeks ago after I press 6-express cook stopped and all the lights and clock went blank. In a 10-15 minutes it came back on and the clock would have to be...
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
199 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
