Question about Sub-Zero 561 / F
Our Sub-Zero hen door squeaks really badly whenopenned or closed.
  • 29 Answers
Take a Q-tip and apply vaseline around the hinges
Posted on Jan 02, 2011
Sub zero refrigerators 632 door won't stay closed
Thee is a plastic cam at the bottom hinge of the door. Mine cracked and I bought a new one online for like $30 (for a piece of plastic). Got a strong friend to lift the door off the hinges while I replaced it. make sure you get the right one for left or right doors.
7014663 Sub Zero Refrigerator Bottom Cabinet Hinge Cam LH (7014663) (7014663) - Genuine Refrigerator Parts
Sep 01, 2014 | Sub-Zero 632 / S
Door slow closing sub zero 650
The door cams are worn under that door, this unit takes two, one for the door, the other for the hinge. They are different too.
Good Luck
Jan 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
My door on my subzero refrigerator squeaks really bad. How do I fix? Model 632
Spray a bit a WD-40 on the hinges and then wipe off the excess...give it a couple of days to work into the hinge...
heatman101
Sep 11, 2010 | Sub-Zero 632 / S
Problem openning door
when you close the door a reverse cycle fan sucks all the waisted air the fridge has just been exposed to out of the unit so it creates a good seal around the door rubbers this is perfectly normal .
please rate ..
Jul 04, 2010 | Sub-Zero 642
Closing and opening a sub zero door
Maybe I'm not understanding your question completely.. You can open the doors whenever you want - as often as you like. The doors are no different than any other fridge as far as how often you can open and close them. Please clarify if I missed your intent. Thanks!
Jun 17, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650: freezer drawer rollers squeak. Any ideas?
dry them off then spray with silicon.also good for cutain tracks.......plastic/metal.
Apr 09, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero freezer door no longer vacuum seals when the door closes. There is nothing obstructing the door.
Make certain that the freezer fan motor is operable. Otherwise, contact an appliance service company.
Feb 20, 2010 | Freezers
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Refrig lights go on and off intermittently when opening and closing refrig door
check door light switch with ohmmeter. Check for melted insulation near light "terminator". Look for wiring diagram in ziplock behind compressor grille. Second switch at door turns compressor off when door opened. I had these problems with a 695 which I would assume is probably similar in design.
Dec 26, 2007 | Sub-Zero 680 / F
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
472 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
