Question about Maytag MAV3855A Top Load Washer
White smoke coming from the machine, it was in the middle of the extended cycle. stopped machine and unplugged. Smells as though something burned.
  • 312 Answers
Usually the first repair a Maytag washer needs is to replace the belts. They can wear out and smell.
The belts are located on the very bottom of the machine. They are not covered. If you pull out the washer about 2 feet and lean it back against the wall you will see the belts on the bottom.
If they have shiny parts, or one of them was sticking. You will be able to see if it is burned.
I've made a diagram to help.
The "main drive pully" is the belt that is most likely to be burned. It is also possible for a clothing item such as a baby's sock, to get caught in the pump. That being the case, the pump belt can burn.
If you replace the belts, which you should do if the machine is 10 years old. You must replace them with Maytag belts. This is important, because they are designed to allow some slippage. If you replaced them with belts of the correct size but not the right type, the machine will not work properly.
Of course, the machine can have electrical problems, but it is rare. Let me know what you find and I can advise you further. Happy New Year, Mark
Posted on Jan 02, 2011
I have a dura flame electric fireplace and I turned it one and it smells like something is burning. I tried to vacuum it and I turned it back one and it still smells like something is burning. it is a
when things are brand new that produce heat they will smell funny for awhile but give it a couple days and it will not if you see smoke then get excited and unplug.
Jan 28, 2015 | Duraflame L Electric Stove with Remote
4g15 engine carburetor smoking only when engine is cold
smoking from where?, front of car, middle or tail pipe.
is this your first car, or first car and first winter (white steam?)
there are 3 kinds of smoke
black , carb flooding (ask why)
white, oil, burning, take for ever to go away
white steam, goes away fast and smells like Antifreeze, sweet and nasty.
and all carbs smoke black in the tail pipe end, when cold, unless
you very carefully tune the choke plate.
so do tell? what?
Jan 04, 2014 | 1995 Toyota Hi-Ace
My calypsal washer smells like burning electrica or rubber in the spi mode
The motor could be leaking oil. Pull the machine out and look for stains or puddles on the floor.
Oct 07, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
Maytag atlantis series mav6200aww, there was a burning rubbery smell today when it was in the spin cycle. I turned it off and unplugged it what could it be
could be a belt and or the pulleys under the machine are plastic so one of them could have melted along with the belt smoking. could be something in pump or look in washer and see if there mite be a nail or something like a nail in one of the little holes in the inner tub . the nail could be making the machine not spin and could be causing the belt also to smoke.
Apr 01, 2012 | Washing Machines
I have a 2001 ford ranger and white smoke is coming from my tailpipe that smells like gas
your tail pipe is always going to smell like gas the white smoke is oil being burned from worn out valve guides or rings.
Dec 09, 2010 | Ford Ranger Cars & Trucks
PONITAC GRAND AM 1999/ STALLING SMELLS OF BURNING GAS
White smoke tells me that you have entered the land of "blown head gasket" Is temp normal and coolant full? If not, you are definitely there. Job is not difficult for a reasonably experienced tech, if you're not, either get a manual and follow instructions very carefully, or, bring it to a reputable shop. Parts are under 300... Don't forget to replace cylinder head bolts (they might look OK but are not to be re-used.)
Dec 28, 2008 | Mazda RX-8 Cars & Trucks
My washing machine stops mid cycle
issue where washer stops and water won't drain might mean something is in drain area.
look at my issue "eco smart won't drain, smells hot" and see about the sock. I found one of my husband's socks so far down in the tub bottom that I couldn't see it when I looked between plastic outer liner and wash tub. Had to remove black motor/white housing on bottom of machine--which i had to replace cause it burned out. That is when I saw the sock and pulled it out through a quarter-sized hole.
Jun 26, 2008 | Fisher Paykel EcoSmart GWL15
Washer emitting burning smell and smoke on fast spin
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
Oct 28, 2006 | Hotpoint WMA35 Front Load Washer
Maytag MAV3855A Top Load Washer Logo
229 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
