Question about Kenmore Dryers
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
  • 472 Answers
I ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Posted on Jan 02, 2011
My kenmore dryer will not turn on. I checked the breaker and outlet and there is no power
ARE U SAYING UR BREAKER IS BAD? REPLACE IT OTHER WISE U HAVE A BAD APPLIANCE TERMINAL BBLOCK
Jul 01, 2014 | Kenmore Dryers
Kenmore 70 series won't start I have check circut breaker and plug
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2011 | Dryers
Circut breaker turned off and turned back on machine will no longer turn on.
Be sure you have 220 volts at the outlet. If you do check voltage on the power cord inside the machine. Be sure the timer is set correct and check the start switch.Does the motor run? If the motor runs and the drum don't turn may be the belt broken or slipped off the pulley. If motor don't run check voltage to motor if you have voltage most likely the motor is bad it can be checked with an ohm meter. Last resort could be timer. Hope some of this helps.
Jan 02, 2011 | Kenmore 64992 Electric Dryer
Drying will not start - already trying resetting it
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 11, 2010 | Kenmore 63942 Dryer
Wont start , The circut breaker tripped, when i restarted it, the dryer worked but not the washer
Hello. The dryer and the washer are on seperate breakers. Check all of the breakers by turning one all the way on, then all the way off, then all the way on again. Do one at a time.
Oct 28, 2009 | Maytag EPICz 6.7 Cu. Ft. King-Size...
Where is the circuit breaker or fuse on a Kenmore Gas Dryer?
no heat usually means your only getting110 volts into your dryer.....you need the full 220volts to run heaters....with voltage meter you checkwires on the plug OUTLET...or inside back cover REDwire to WHITEwire =110v.........BLACKwire to WHITEwire =110v.....REDwire to BLACKwire =220v. you probably have aBAD 220V. 30 amp circut breaker..or if still using FUSES one is burnt out (In house electric panel) or burnt off RED or BLACKwire in back of dryer.....
May 09, 2009 | Kenmore 63942 Dryer
Help
most of the time it is the door switch that goes bad or the main fuse on the blower box inside fails,you can also check to make sure the dryer wall vent hole or dryer hole is free and clear,let me know what you find-mike
Oct 29, 2008 | Kenmore 63942 Dryer
Kenmore model #86982800
check power cord connections for tightness with the power OFF
May 08, 2008 | Kenmore 64992 Electric Dryer
Won't power on
U have only 120 vac, need 240 vac. Turn the 30 amp breakers hard to off then back on. Should do the trick
Apr 29, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
