Question about Brother Office Equipment & Supplies
Brother MFC- 6490CW 6wks old Screen shows "Error
    Sergeant:
  • 194 Answers
To adjust your Brother machine's paper type and size settings follow the instructions listed below:
To get the best print quality, set your Brother machine for the type of paper you're using.
You can use seven sizes of paper for printing and copying: Letter, Legal, Ledger, A3, A4, A5, and 4 x 6 in (10 x 15 cm).
You can use five sizes for printing faxes: Ledger, Letter, Legal, A3, and A4.
When you change the size of the paper you load into your Brother machine, you must also change the machine's Paper Size setting.
  1. Press Menu.
  2. Press the up or down arrow key to select General Setup.
  3. Press OK.
  4. Press the up or down arrow key to select Tray Setting.
  5. Press OK.
  6. Press the up or down arrow key to select Tray #1 or Tray #2.
  7. Press OK.
  8. Do one of the following:
    • If you selected Tray #1, please follow these steps:
      1. Press the left or right arrow key to select the paper type you want to use.
        - You can select Plain Paper, Inkjet Paper, Brother BP71, Other Glossy, or Transparency.
      2. Press OK.
      3. Press the up or down arrow key to select Paper Size.
      4. Press the left or right arrow key to select the paper size you want to use.
        - You can select Letter, Legal, Ledger, A3, A4, A5, or 4 in x 6 in (10x15cm).
      5. Press OK.
    • If you selected Tray #2, please follow these steps:
      1. Press the up or down arrow key to select Paper Size.
      2. Press the left or right arrow key to select the paper size you want to use.
        - You can select Letter, Legal, Ledger, A3, or A4.
      3. Press OK.
  9. Press Stop/Exit.
Posted on Jan 02, 2011
I have a MFC-6490CW and when i scan A3 it cuts off the sides of the page when i scan to file
Hi
Please select the auto select paper size option, if this don't fix your problem then go the paper option and manually select the A3 paper size and scan.
Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
Window says wrong paper size reload correct paper
its in setting on printer icon put it on full page.
Feb 26, 2011 | Brother MFC 6490CW InkJet Printer
How do I select paper tray 2
You can set the Brother machine to automatically select the appropriate paper tray based on the paper size or you can manually select paper tray1 or 2. If you use the Auto Select feature, the application will automatically pull from the appropriate tray based on the document#s paper size. For this feature to work, the tray settings must be definedfrom the machine#s control panel. For instructions on how to configure this setting, continue to the section labeled: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING)
PART 1: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING
1. On the Brother machine, press MENU.
2. Scroll to and press GENERAL SETUP.
3. Scroll to and press TRAY SETTING.
Oct 29, 2010 | Brother MFC 6490CW InkJet Printer
HOW TO SET UP MFC-6490 TO SCAN 11 X 17 DOCUMENT
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file. There are two tabs at the top, change the paper size at bottom of each to ledger and press ok.
Jun 17, 2010 | Brother MFC 6490CW InkJet Printer
Paper jams??
click here to download yor required drivers
May 12, 2010 | Brother MFC 6490CW InkJet Printer
I have a Brother MFC-6490CW and I want to scan paper that is 11x17 and the manual says that i have to set my glass size. However, they say to push the Scan button and then the Scan to Media button...that...
Dec 13, 2009 | Brother MFC 6490CW InkJet Printer
136 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
