Question about Frigidaire Washing Machines
Washer dial does not move automatically - Frigidaire Washing Machines
    Scholar:
  • 148 Answers
You need to replace the timer
Posted on Jul 08, 2008
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
Ge front load washer won't spin automatically
then I can only think you need a new timer motor . call a repairman
May 11, 2016 | GE GFWN1100LWW
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
Apr 06, 2011 | GE Washing Machines
Cycle dial doesn't advance automatically anymore. I saw some listed problems that sounded similar, but not exact. Washer will work in all cycles, but only when I watch and move the dial manually.
Hello & Welcome to FixYa
Its seems that the Timer is stuck, as everything else is working fine in the unit and the dial ust gets stuck and so won't complete the cycle so the problem is with the Timer motor going bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 24, 2010 | Kenmore 15522 Built-in Dishwasher
Washer dial problem on whirlpool LSB6000PQ
HI, This will occur when the timer mechinism(washer dial) has failed. The main cause of this type of failure will be timer motor breakdown. The timer motor is essential to the sequential balance of the cycle that is selected. If it is unable to rotate the dial properly, it will not allow the unit to operate correctly.
Replacing the timer module will correct this issue you are experiencing at this time.
Sep 11, 2009 | Whirlpool LSB6000PQ Top Load Washer
The washer will not move forward automatically. I
it may be the timer or the heater has gone faulty in which it will not advance the timer from the stats. is it heating ? if not theres your answer, if so it may be the stat or the timer itself.
Mar 16, 2009 | Washing Machines
Dial won't move automatically
The dial is not a timer that moves through the prog, it is a selector switch, which selects the programme you require, and therefore does not move round
You need to check the filter re the spin prob.
Remove rear panel, remove large black hose from bottom of tub, remove filter, and clean.
Refit filter and hose.
Test for leaks
Plz rate my solution.
Thanks
Jan 11, 2009 | Hotpoint First Edition WMA20 Front Load...
Loud spin, doesn't fill, dial doesn't move.
yes you do have to remove the top off the washer and the washer should come with a mounting kit that must be used when stacking this unit. as far as your filling and draining problem i have had this problem several times before you have to replace your speed control board or sometimes called the speed control unit in the lower right hand corner of your washer
Sep 08, 2007 | Kenmore 43142 Front Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
