Question about AOC 2036sa 20"TFT LCD Monitor
I have just installed a new AOC 2036S monitor, but there the color red is not displaying on the monitor at all.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AOC Master
  • 848 Answers
I have just installed a new AOC 2036S monitor, but there the color red is not displaying on the monitor at all? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
8921MYD1 715G2892 2 3 AOC ADTV8921MYD1 Power Supply Backlight Inverter for...
Posted on Jan 25, 2015
  • 11,361 Answers
All the pins on the video cable are OK on both ends and they are on tight? Try it with another PC to make sure it is not video card problem also.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jan 02, 2011
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Comes on and starts to come up then it goes blank
try reserateing connections but it may be blown capacitors. while reseatind have unit powered off then power on after all connections have been unplugged then replugged. if this helps, please rate with a comment
Feb 07, 2013 | AOC International TFT20W90PS 20 Lcd...
AOC 2036s shuts off after seconds
my aoc monitor 2036s is blinking when i run hd movie or play game . what can I do for fix my problem. please suggest....
Jan 28, 2012 | AOC Computers & Internet
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 | AOC Monitor
I bought an AOC 2036s monitor in the usa, came back to australia to connect it to my laptop as a second screen. yet it wont seem to work, i keep getting no signal. the box saids compatible with XP, yet...
USA mains equipment operate on 110 volts. Unless the AOC monitor can operate on multi voltages ie 110 to 240 volts, when you connect 110 voltage equipment into 240 volts mains in Australia you most likely will damage the AOC monitor.
To operate equipment that has been designed for 110 volts, you need to purchase a step down transformer from 240 to 110 volts that has suitable wattage rating for the AOC monitor.
Feb 24, 2011 | Computers & Internet
Used the cd that came with the monitor. Now size, pixels, etc. are wrong, so much so that it cannot be used. How do go back to pre-cd-use? Thank you AOC 2036S Serial # Q81A8HA267758 LCD 20 inch...
If You really can't read anything on the screen this wont help. If you can make out a bit, then right click on a vacant area of your screen, then select "properties". On the Display Properties Menu, select "Settings", then select "Advanced". This will bring up a menu that shows your Monitor and Display Driver info. Select "Display", then select "Properties", then select "Driver", then select "Roll Back Driver". This will restore the old driver for the Display. If this doesn't help, go through the same menus again, and on the "Monitor and Display" menu select "Adapter" instead of "Monitor", and roll back that driver.
Best of Luck
Dec 08, 2010 | AOC 2036sa 20"TFT LCD Monitor
My AOC 19" color display turns red, whats the reason of this?
my 3 aoc tft1560ps 15inch back light is off plsss help me capacitor replace already
Jun 26, 2010 | AOC LM729 17" LCD Monitor
AOC LM725 Color Cycle
AOC brand are disposable, now if your going repair its chips, its definitely work or not... i tell you this monitor is very deliquate to work normally.... buy a new one...
Jun 16, 2009 | AOC LM729 17" LCD Monitor
Bought new aoc monitor and plugged in and all I get a floating screen safer saying "input not support".
Your display resolution is set to something outside the range your AOC supports.
Start Windows in VGA mode (pick that option from the startup menu you get when you press F8 after the manufacturer's logo comes when you turn the computer on). Then set the display mode to 16-bit color and 800X600 resolution. This will allow Windows to start up next time with settings just about every monitor can handle.
Once WIndows is up and running, make sure you change your display settings to something the monitor can handle. Specs are in the manual or on the manufacturer's website, but resolution of 1024X768 should be another safe choice. You should also think about installing any driver software supplied with the monitor.
Dec 08, 2008 | Computers & Internet
AOC 2036sa 20"TFT LCD  Monitor Logo
224 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
