My Mac Pro just gets a black screen each time I turn it on. The most it has lasted is 5 minutes and the same problem occurs. It has been just about over a year and unfortunely I dont have an extended warranty for it. Is there anything I can do to fix it? Thanks
    President:
  • 2,653 Answers
If the screen goes black after 5 minutes that usually indicates an issue with the display inverter.
I wouldn't recommend you trying to fix it yourself since working on Macs isn't easy for non-techs.
I'd recommend you finding a local mac tech on craigslist or Yelp.
Total cost should run around $40-60 depending on your tech.
Hope this info helps ;)
Posted on Jan 02, 2011
Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Apr 14, 2014 | Apple Computers & Internet
How do i fix my macbook pro?
Is it plugged in? Is the battery functioning? Try holding down the keys command/option/p/r while turning the power on to your mac. Let it reset a couple of times. You will know it is resseting by hearing the apple chimb several times.
Jun 25, 2013 | Apple MacBook Pro PC Notebook
Have a macbook pro and it has locked up, black screen now and isn't responding to mouse or keyboard
This has also happened to my Macbook Pro - nothing would work, so i basically pressed the power button until it closed down and waited a few minutes and turned it back on. The problem ( touch wood) did not come back again yet. Good luck!
May 18, 2011 | Apple MacBook Pro Notebook
Hi i have a toshiba satellite pro l450d series how do i get it back to factory setting please
1. Make sure to back up all the important files that you have in your computer. 2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
Hopefully this will help you..:)
Apr 16, 2011 | Toshiba Computers & Internet
ASUS monitor is plugged into MacBook Pro. Has worked fine over the last 12 months with both screens working independently. Recently unplugged for 2 months. Plugged ASUS back in. After approx.5 minutes, the...
(1) If you have connected windows cpu to monitor then when you power up the computer press F8 key then enter in enable vga mode then go to control panel ->display property -=>settings change screen resolution to 1024*768.
then check .
(2)But if you are not able to see any display on screen then open cpu cabinet and refix ram memory pull cmos cell from motherboard for 10 minutes ,if there is any pci card or vga card installed on motherboard reattach it into motherboard.Then check.
If you have mac book then follow my second solution.
Let me know if you need further assistance.
Thanks for using Fixya.
Apr 07, 2010 | Computers & Internet
Help! I dropped a tv onto my macbook pro 2 ghz c2d three days ago and it worked fine until last night when a strange, matrix like green half image started flashing on the screen. I rebooted and now the...
Twist the Macbook body while turning it on. If that make the image come back, you have a broken logic board. There are Mac Repair Guides that show how to open a Macbook. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Mac Repair NYC.
Dec 04, 2009 | Apple MacBook Pro Notebook
Screen image turns red after 15 minutes
Ur backlight video board it,dying.Micro processor have shorted,must change the backlight board.
Nov 24, 2009 | Polaroid FLM-3232 Television
Macbook Pro goes from gray apple screen to black
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Apr 25, 2009 | Apple MacBook Pro PC Notebook
MacBook Pro Black screen and shining sleep indicator
is the battery fully charged? try plugging it in then press the power button again.
Jan 10, 2008 | Apple MacBook Pro PC Notebook
Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
Sorry to inform you my freind, but the main board has to be replaced in this beast. Could get expensive. there are no schematics and or componets listed to repair this module. Its a board level repair only. Try going to ptscorp.com, find their phone number, and see if they repair these boards. if not you will need to contact the manufacturer for replacement boards. good Luck Please do not forget to rate this thread.,
Dec 15, 2006 | Fujitsu Plasmavision PDS-4209 42 in....
Computers & Internet Logo
David Payne
David Payne
