SOURCE: ultra mp3 lisence key
Just download new version with keygun from here :
http://rapidshare.de/files/16936965/UltraMP3-v1.51-S60.rar.html
SOURCE: How do I unlock nokia 2630?
1552055633
the master code of ur cell.. try it!!
Do rate if this solution was helpful..
SOURCE: Please help I need smartmovie 3.41 license key
you can get software and keygen from site dotsis.com
SOURCE: unlock key? IMEI: 357932082920078... email me @
licinse key for LCG jukebox?
imei: 357932000788292
Select Service setting using the up/down cursor keys.
While pressing the start key and the # key, press the enter key.
Select Maintenance mode using the up/down cursor keys.
Press the enter key.
Enter the maintenance item number (163) using the up/down keys.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Turning power switch off and back on
Resetting the fusing problem data
Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Completion
Description
Purpose
Method
Completion
Shawn
