Question about Midland Radio Communications
I have the portable handheld and it makes a static sound every minute or so as if I pressed the talk button. Is this normal? If not, how can I get rid if that?
    Problem Solver:
  • 44 Answers
Check squelch
Posted on Jan 03, 2011
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
My hand held connot hotsync with my P.C. A message comes up that there is a problem and the program has to close. I un installed the program and re installed it and the program continues. I have had...
This can be a problem between the connection of the PDA to the PC that's why the software cannot synch them so first thing that you can do is toi make sure that computer and pda are communicating fine if possible try a different cable to connect them, then if still have the same problem, best way is to use a different computer to sync your pda...
Hope that helps..........
Sep 04, 2008 | Computers & Internet
I have a pn58c8000 and sometimes the sound has problems. I can never predict when the problem will happen. The sound will become very high pitched and everyone talks in high squeaky voices like only the...
make v reset press the exit button on remote for more than 10 sec message reset will appear select yes tv will turn of turn tv back on and select home use this could repaire your problem
Mar 26, 2011 | Samsung PN58C8000 TV
Motorola TLKR T3 communication problem
svp dite moi comment les refaire marcher car il y en a un qui recoit tout et l'autre rien du tou svp aider moi
Oct 04, 2009 | Motorola Talkabout T5720 (7 Channels)...
Need a phone reset
Part 1
Soft Reset
A soft reset tells your handheld to stop what it's doing and start over again. All records and entries stored in your handheld are retained with a soft reset. After a soft reset, the Welcome screen appears, followed by the General Preferences screen.
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
Reset Tip Tool: On most PalmOS handhelds, the stylus that comes with your handheld has a reset tip inside. To use it, unscrew the barrel from the stylus quill.
Double-Soft Reset
If your device doesn't seem to want to power up after a soft reset, and you've checked the other obvious solutions (fresh batteries, power button, contrast wheel, contrast button) you may want to try the 'Double-Soft Reset'. Simply perform a soft reset as directed above, but press the reset button twice in quick succession.
Warm Reset
A warm reset bypasses any system extensions (such as HackMaster hacks, OS patches, Alarm settings, etc) that are loaded on your handheld. Sometimes a damaged third-party application will try to respond to a reset but will fail and cause the handheld to 'hang'. Using a warm reset, you can start the handheld, then delete the damaged application before it has a chance to try to run again. After deleting the application, follow with a soft reset to start up the handheld normally.
To perform a warm reset:
  1. Press and hold the upper half of the scroll button on your handheld.
  2. Using the reset tip tool (or a similar object without a sharp tip), gently press the reset button inside the hole on the back panel of your handheld.
  3. When the Palm Computing Platform logo appears on the screen, release the scroll button.
If you're not sure which application is damaged, you can use a tool like ResetEmu in conjunction with a warm reset to help pinpoint the offending application.
Hard Reset
With a hard reset, all records and entries stored in your handheld are erased, except for the default or specimen databases predefined by the manufacturer (but see Extended Hard Reset below). Formats Preferences and other settings are restored to their factory default settings. You can restore any data previously synchronized with your computer during the next HotSync operation. If you're running OS 3.1 or earlier, and you're not using a third-party backup utility like BackupBuddy, you may need to reinstall your third-party applications.
Never perform a hard reset unless a soft or warm reset does not solve your problem.
To perform a hard reset:
  1. Hold down the power button on the front panel of the handheld.
  2. While holding down the power button, use the reset tip tool (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
  3. Release the reset button.
  4. When the logo screen appears on the screen, release the power button.
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press the upper half of the scroll button on the front panel of the handheld to complete the hard reset and display the Digitizer screen.
Pressing any other button instead of the upper half of the scroll button will perform a soft reset.
Extended Hard Reset
An Extended Hard Reset will completely erase your handheld, and will also bypass the creation of some default databases.
This differs from a normal hard reset, which will automatically create the databases for the built-in applications, and will insert some specimen records into those databases: numbers for Accessories and Technical Support will be created in your Address database, a registration reminder will be created in your ToDo database, and several helpful memos will be created in your Memo database.
In addition, a normal hard reset will also create a Network database with some default Network profiles for your Network panel in Prefs, and a file of several default MIDI alarm sounds will be created.
If you have the Notepad application, a normal hard reset ensures a sample note will appear on your NotePad, and if you have the Mail application, an email message from 'Mail Help' will be automatically inserted in your handheld Inbox.
An Extended Hard Reset will ensure that all of these startup files are not created.
If you decide to perform an Extended Hard Reset and install one or more third-party applications that expect to see the built-in databases present, you may encounter an error. For this reason, it's suggested that after an Extended Hard Reset, you run each of the built-in applications (Datebook, Address, ToDo, Memo, and if installed, NotePad and Mail) at least once to ensure empty built-in databases are created.
After an Extended Hard Reset, you will not be able to select alternate alarm sounds for Datebook alarms, but the default alarm sound will still be heard for appointments with alarms set.
To perform an Extended Hard Reset:
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press and hold the upper half of the scroll button on the front panel of the handheld.
  6. While still holding down the scroll button, press, in any order, the Datebook button, the Address button, the ToDo button, and the Note/Memo button.
  7. Release the scroll button, to to complete the hard reset and display the Digitizer screen.
Pressing some but not all the buttons while holding the scroll key will result in a normal soft reset. Pressing no buttons while holding the scroll key will result in a normal hard reset.
Feb 18, 2009 | Palm Treo 650 Handheld
BlackBerry 8700c Hang-up
Try to take the battery first and leave it for 3 hours and put it back again,and try to check if the screen respond in tapping if still not working then do some reset procedure...
Soft Reset
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your palm handheld.
Double-Soft Reset
Warm Reset
Hard Reset
Extended Hard Reset
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 04, 2008 | RIM BlackBerry 8700g Smartphone
Scanner static
Use the channel lock out control, unless it is a frequency that you listen to, you may have interference that is causing random static. use a noise filter mechanism to minimize this problem, or buy a specialized scanner antenna that's guaranteed to minimize static.
If no avail, you may need to send it in to a store.
Hope this helps!
Jul 01, 2008 | Uniden BC60XLT-1 Handheld Scanner
Static
SYSTEM RESET To recover from some fault conditions (refer to the Troubleshooting Section) you may need to perform a system reset. To perform the system reset follow this procedure: 1. Press both the talk button (14) and the mute control (15) button on the headset for 5 seconds. 2. When the talk indicator light (17) on the headset blinks, release both buttons. 3. Press the talk button again. 4. Next reset the base unit by disconnecting the AC power adapter (24) from the AC power adapter jack (7) for 5 seconds, then reconnect. The system reset operation is complete.
Jun 19, 2008 | Plantronics CS50 Wireless Office Headset...
Radio Communications Logo
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
