Question about Iomega ScreenPlay
I HAVE 1 TB IOMEGA SCREENPLAY DIRECTOR. INITIALLY I CONNECTED THE IOMEGA TO PC WITH WINDOWS XP AND TRANSFERRED MEDIA FILES. I AM ABLE TO READ THE FILES ON TV AND LISTEN/SEE THE AUDIO AND VIDEO CONTENT.LATER I TRIED TO CONNECT IOMEGA TO LAPTOP WITH WIN 7 AND TRANSFER SOME MORE VIDEO FILES.BUT LAPTOP COULD NOT RECOGNIZE IOMEGA . THE ERROR MSG. IN MY LAPPIE WAS " ONE OF THE USB DEVICES MALFUNCTIONING".ALL USB PORTS OF MY LAPTOP ARE WORKING PERFECTLY. CAN ANYONE PLEASE HELP ME OUT AS FAST AS POSSIBLE.
SOURCE: Remote code for the iomega screenplay
I bought the JELLY Universal PC Programmable remote in Portugal for 10 euros. The code for Iomega Screenplay is 2297. See it here: http://www.wiltsgrove.co.uk/sub-category.php?ID=1709&CID=0026&PID=IR2005
Posted on Mar 30, 2009
SOURCE: Iomega Screenplay Pro HD - No Menu
I had the same problem with the Screenplay Pro HD. My Iomega was working fine and one day after exchanging files with a friend I got the logo, then the loading message and then it went into a black screen while the blue light kept blinking.
Obviously the connection to the TV was fine because the logo appeared.
I solved the problem by downloading and reinstalling the firmware.
I downloaded the firmware from the iomega web site.
Notice that during the installation process you get the message that it will delete your data and then shortly after you have the option to delete or keep it. Hang in there. This part is a little nerv wrecking.
Hope this helps.
Rainer
Posted on Jan 03, 2010
  • 71 Answers
SOURCE: Resolution not supported error on Iomega SCREENPLAY HD 500gb
Avi files should be 700 or below when playing on a conventional tv,625 or 525 prefered.
if set to hd format trough HDMI output the display warning will not appear has the iomega will upscale trough the HDMI output,and will suport any resolution.
Posted on Jan 20, 2010
SOURCE: Iomega Screenplay Pro HD Multimedia Drive works on PC but not on
If the blue light continues to flash after the screen goes black, then you need to reinstall the firmware. Look at http://screenplayprohd.wikia.com for information about getting the firmware and installing it.
If the blue light goes solid after the screen goes black then you probably just need to switch the NTSC/PAL selection. Press that button on the front panel several times, waiting a few seconds inbetween in press. If it continues to be invisible, plug the drive into another TV using the composite cables instead of HDMI to confirm if the menu comes up at all. If it does, reinstall the firmware.
Posted on Apr 06, 2010
SOURCE: my iomega screenplay director is having problem
DTS audio only works with Optical Cable. If your TV/Surround does not have optical buy a Optical to Coax Converter.
Posted on Oct 13, 2010
Iomega screenplay director firmware
Iomega i ScreenPlay Director SPDHD - Lenovo Community
forums.lenovo.com > ... > Iomega Desktop Network Storage
Nov 16, 2013 - 5 posts
Hola, tengo un iomega screenplay director y hasta ayer me ... aqu?: Versi?n 1.4.0.92 del firmware de ScreenPlay Director: Leer primero Iomega Screenplay Director HD doesn't work on TV
Mar 15, 2015
Firmware Iomega screenplay HD500
Feb 9, 2014
How to find, download and install firmware on my i...
Jan 14, 2014
Iomega ScreenPlay Director error 12
Jan 10, 2014
More results from forums.lenovo.com
Dec 25, 2015 | Iomega ScreenPlay Director 1TB HD Media...
Screenplay hd doesnt show files in it
Are the files "hidden"? If the PC does not see the files, what device did you use to load the files into the Iomega MX? Try going back to the file-source and right-click on them, select 'properties'-> undo 'hidden' check-box. This may fix it.
Jan 03, 2013 | Iomega ScreenPlay Director HD Media Player...
How do i connect my iomega screnplay director for the first time?
First Time Setup: 1. Connect the power supply to the ScreenPlay Director and an uninterruptible power supply (UPS) or power outlet. 2. Press the power button on the front of the ScreenPlay Director to turn it on. 3. Turn on your TV and change the input setting as needed to receive input from the ScreenPlay Director. 4. When the ScreenPlay Director setup wizard appears on the TV screen, select your language and the TV screen aspect ratio, then configure your network connection. Refer to the user's manual if you need additional instructions. NOTE: If you wish to skip the network configuration during first time setup, you can add it at a later time using Settings from the ScreenPlay Director home menu. See the user's manual for detailed instructions. ----------------------------------------------------------------------------------------------------------------------------------------- If you need any other information about your device, I would suggest looking at the user's manual as it will pretty much answer any other questions you have about your device. Click on the blue links below. ScreenPlay® Director HD Media Player User's Manual: View Online [HTML] ' Download [1.0MB zipped HTML]
Quick Start Guide [PDF 1.2MB]
Specifications
Dec 23, 2010 | Iomega ScreenPlay Director HD Media Player...
I formatted the screenplay director hd drive and just have a screen saying :sleeping waiting for usb keys:
ScreenPlay Director Partitions
There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files.
The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection.
The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface.
Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
************************************CAUTION!************************************************ Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
Conclusion: If you have deleted or formatted any of the first 4 partitions on the unit that is not the data partition. You now own a BRICKED ScreenPlay which HAS to be replaced. No if ands or buts about it. YOUR DEVICE IS DEAD.
Dec 19, 2010 | Iomega ScreenPlay
I purchased an iomega 1TB screenplay director at P.C world in the U.k On my return to Spain I discovered ther was no "users manual" in the box, only the quick set up guide. Obviously I do not want to...
ScreenPlay Director HD Media Player:
User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/spdirector/en/main.html
Download [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
Quick Start Guide [PDF 1.2MB] http://download.iomega.com/qsg/spdirector_us.pdf
Specifications https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=22159
Oct 12, 2010 | Iomega ScreenPlay Plus 34499 Digital Media...
I have accidentally formatted the default partitions
*******************************************CAUTION!*********************************************************
Oct 09, 2010 | Iomega ScreenPlay
How can I format my Screenplay Director?
Formatting the Data Partition
The data partition on the ScreenPlay Director is formatted with an NTFS file system and will appear as a read-only volume under Mac OS X unless special software is installed on the Mac. If you need to transfer files to the ScreenPlay Director by direct USB connection on a Mac, you must reformat the data partition to FAT32 (see instructions below).
NOTE: On a network connection, Mac OS will see the ScreenPlay Director as a shared SMB volume. This means you can use the network to copy files from a Mac to the ScreenPlay Director without changing the format from NTFS to FAT32. (Recommended if available.)
If you reformat the ScreenPlay Director data partition for use with a Windows PC, it is recommended that you use the Windows format utility to reformat with NTFS. Right click on the drive letter for the data partition and select Format.
CAUTION!
  • Do NOT change the partitioning on the ScreenPlay Director as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition can be viewed or played on a TV.
  • Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
May 19, 2010 | Iomega ScreenPlay
I deleted some of the partitions and now the
ScreenPlay Director Partitions There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files. The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection. The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface. Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
*******************************************CAUTION!********************************************************* Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
May 06, 2010 | Iomega ScreenPlay
I have bought a IOmega Screenplay Pro 1 TB. I was able to see some partition in the HD. Accidentally all these partition were removed. So i need to create those partitions and the size details of each...
Feb 22, 2010 | Iomega ScreenPlay
I have a IOMEGA Screenplay Pro HD 1 TB drive. It was all working fine on TV and PC. But suddenly after I used it with my PC for transferring files, I switched it off and then connected it to the TV. Now...
have u tried the tv sys button on the remote ? reperat a few times as it cyclels thru the formats. or the source button. first disconnect the usb
-will power
Nov 13, 2009 | Iomega ScreenPlay Pro MP3 Player
Iomega ScreenPlay Logo
Top Iomega Televison & Video Experts
Martin Murray
Andrew Taylor
Andrew Taylor
Are you an Iomega Televison and Video Expert? Answer questions, earn points and help others
