Question about Northstar Electric Wet Steam & Hot Water Pressure Washer 1700 PSI
Will not start up when cold out have to warm it up to get it to start
  • 31 Answers
I would check too make sure you have the correct motor oil usualy a lighter grade oil for winter months
Posted on Jan 02, 2011
My leaf blower starts cold but won't start warm
Test for spark when it is warm. You may have a damaged ignition module.
Oct 06, 2014 | Garden
Bottom falls out of idle after revving engine cold
Its probably a problem with the water temperature sensor. Also do not rev a cold engine. The engine has a "cold start sequence" which is similar to a choke. When the engine gives a cold signal, the fuel mix is made richer and the timing is changed until the engine warms.
Let the engine warm at the preset factory settings. Sometimes the O2 sensors will cancel the cold start sequence before the water is warm. Racing the engine will warm the O2 sensors too quickly.
May 14, 2014 | 1993 Mercury Grand Marquis
1995 S10 vin W 4.3 cold start problem. Warm start OK. Suspect temp sensor. Cannot locate it. Location/other ts ideas?
There are multiple temp sensors on that ,. One is in the MAP sensor and the other is the radiator. What is extremely cold?
Dec 02, 2013 | Chevrolet 1995 Chevrolet Blazer S10/jimmy...
Won't start when cold
The cold start valve could need replacing. Also when cold, condensate gets on the wiring causing it to run rough until things warm up. Try covering it up at night. Check your plugs are OK.
Nov 20, 2013 | 2004 Honda Silverwing 600
My wifes 2003 toyota highlander when she starts it there is what appears to be a gas fume like smell in the car. it seems to go away when the engine isd warm
You should have the fuel injectors and the especially the "cold start injector" checked for leaks. The cold start injector only operates during cold starts. If you don't notice the problem during warm starts, then the cold start injector is the place to start.
Feb 08, 2011 | Toyota Highlander Cars & Trucks
Good day: I don't accept that cold starting an engine at 2000 RPM is OK. Those immediate revs on a cold engine are wearing out parts that need oil lube and warm-engine clearances. Is there a simple way of...
I have heard that Fords theory behind that is to supply maximum oil pressure to moving parts sooner. All the Ford products do this and the motors last well into the hundreds of thousand of miles. I wouldn't be to worried about it since there is no issue with it to my knowledge and there is no way to limit the cold start RPM's.
Cold start warm ups are a thing of the past. Better lubricants, engines, fuel injection and other computer controls have made start ups easier on the engine. 30 seconds is barely enough time to warm up anything and after a few seconds oil has already reached all of its intended lubricating points. That first few seconds is the hardest on the engine. Regardless of how any RPM's it is turning.
Oct 20, 2010 | 2000 Ford Taurus
2.0d x-type 2005 Est. Starting problems when engine is warm
Ok, time for car school. The vehicle is operated by the computer, every electrical concept that is. When the engine is cold, it starts fine because the computer has placed it in "cold start mode", putting more fuel into the engine than normally would until Once the engine is warmed up, a temperature sending unit or temp sensor tells the computer to change to normal run mode. IF said temp sensor is faulty and is not telling the computer to make said change, it stays in cold start mode, still dumping excess fuel in the engine that is now not required, cause it's warmed up. Like keeping the choke closed on older vehicles. Now I think you can answer your own question, when this no start action is happening after warm up and it always starts fine when cold, what's the first thing you check ? Right, the unsuspected temp sensor. Change that and no more start problem. Have a wonderful day. Glad I could be of service.
Jul 11, 2017 | 2005 Jaguar X-Type
Starts cold when warm shuts off
May be the fuel pump, experienced similar problems in 1995 Intrepid. When the pump warmed up, it would start to loose pressure and car would sputter and die, but would start back up. If it started it would usually begin sputtering again and eventually die.
Feb 03, 2010 | 2000 Hyundai Accent
When the car is warm after a while it is hard to start, takes a few cranks. when it starts it smells like fuel. on cold start it is fine.
Kinda sounds like the ECM or "start mixture" control module is faulty or is getting a bad input from a sensor. For example, it man not be getting a proper temperature sense from the exhaust manifold or the intake manifold water temp sensor. So, every start seems like a cold start....
If your cold start is on a "cold" engine - fine. If your cold start is on a "warm" engine - problem. Mixture is too rich for a warm engine.
Again, could be sensor sending a bad temp signal... or the control module not responding to the signal.
A bit too complicated a problem to exactly troubleshoot via long distance... but you now have a starting point.... -Jim
Oct 23, 2009 | Chevrolet Suburban 2500 Cars & Trucks
Cold starts ok warms up shakes and stalls
check engine coolant temperature when it gets warmer, or at operating temperature, and verify that the temperature gauge is showing warmed up to operating temperature. If the coolant temperature sensor tells the computer the engine is cold it will over fuel and miss and the engine will die. When cooled down it will run fine until it warms up. Also could be coil if it starts missing after warmed up.
Aug 18, 2009 | 1990 Ford Bronco II
Northstar Electric Wet Steam & Hot Water Pressure Washer 1700 PSI Logo
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
