Question about Nordic Track NordicTrack Treadmill, A2550
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not work). SPEED button "lower" works but not the higher button. FAN, ODOMETER, PROGRAMS, HEART RATE, 1 through 10 mph buttons or INCLINE none of these will work. This just started, worked fine yesterday. Any suggestions? I sure wanted to get this year off to a good start, but failed. Please help and thank you in advance.
  • Anonymous Mar 23, 2014
    just bought a new 950 and the buttons of the handle start/stop, speed up/dn and incline up/dn buttons are not working
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
DC-6 error on Lifespan Treadmill
Follow attached link to see user manual.
Unplug treadmill.
On page 13 of the users manual, read step 5 part B regarding the wiring harness. Unplug and plug back in each of the connectors of the wiring harness. Plug the treadmill back in to see if it now works. https://s3.amazonaws.com/lifespanfitness/pdf/Manual_TR4000i.pdf
Jul 30, 2014 | Lifespan Fitness TR4000i Folding Treadmill
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
    How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
    Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
    By Jolie Johnson, eHow Contributor
    updated April 15, 2011
    Related Searches:
    The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
    Instructions
    1. Power Turns Off When You're Using the Treadmill
      • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
      • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
      • 3 Remove the magnetic key from the console then reinsert it.
      The Console Won't Turn Off
      • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
      • 2 Hold the "Stop" button down for a few seconds.
      • 3 Press the "Speed" down (-) button. Remove the magnetic key.
      The Incline Does Not Change Correctly
      • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
      • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
      • 3 Remove the key from the console.
      Walking Belt Slows
      • 1 Unplug your C2500 and remove the key from the console.
      • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
      • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
      • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
    Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
    No start no stop of my teadmill t9600 but the other buttons areok
    these are the most often used functions you just worn them out you can call vision fitness they will ask the upper console model and serial # (located on the back end of the console ) Here is their # 1-800-335-4348
    May 13, 2010 | Dmm Vision Fitness T9500 Treadmill
    The buttons on this unit are on an overlay. Basically, the buttons are a big sticker that goes on the console. I would start by checking the connection between the overlay and the console board. If the connections in good, then try a new overlay. If that does not work then the console board is bad.
    Mar 22, 2010 | Dmm Vision Fitness T9500 Treadmill
    Reebok rx3000 treadmill. panel lights up fine. 2 of the 10 speed buttons will not imput and the start button will not start the treadmill. checked the power panel. led lights to voltage light up fine, but...
    it is two items in this case. The light on the PWM will light if you force the belt to move. I would start with a lower board replacement. If it works fine then you need a new console. I have seen this when people use the heart touch bars on the treadmill and get a static shock. this can ruin the console.
    I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
    Apr 18, 2009 | Reebok 8050 ES Treadmill
    Nordic Track NordicTrack Treadmill, A2550 Logo
    1,237 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
     Atlanta Fitness
    Atlanta Fitness
    Level 1 Expert
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
