Question about Arctic Above Ground Rugged Mesh Winter Cover Pool Size: 18' X 40' Oval Armor 8 Yr Warranty
My control panel is not functioning and the fd01 code comes up and runs for a few mins and then the code 079 comes up and then the tub shuts off for a second and does the same thing allover again. the control panel works the odd time on pump2
My livestrong LS15 treadmill stops running after 6 mins. The manual under trouble shooting says it may be the mcb. The display is still on but is nonfunctional.
If you just run the belt with no one on it do you have this same problem or does it run fine? If it runs fine then you need a new walking belt. If it still shuts off then it may be your controller.
Jun 04, 2017 | Exercise & Fitness
Dryer runs for few mins the shouts off
Hello David Neal, I appreciate your post!
I see that you are stating your Frigidaire dryer will run for a few minutes and then shut down. It sounds like a potential problem with your control panel or wiring harness. I would seek assistance from a profession technician to come out and properly diagnosis your dryer to avoid any unnecessary part purchases. I hope this information has been helpful. -Matt
Oct 07, 2014 | Frigidaire Dryers
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Remote Control Programming Codes
The codes below are for samsung tv's. Enter each code one at a time, when you find one that works make sure all of the remote functions are working as some codes will turn th tv's power on and off but will not operate any other functions like volume and chan.+/- 005, 13, 079, 080, 145, 177, 195, 202, 213, 216,227, 255, 260, 266, 274, 275, 282, 295
Dec 02, 2013 | Samsung Televison & Video
I have a Dream Maker X400 hot tub that wasn't used for a year or so, I replaced all of the jet heads and filled it - when I started it the light starting flashing on and off with a clicking sound coming...
Hello, and thanks for the question. Your error code is actually "SN" not "5N" but they are sometimes difficult to discern on the LCD topside display. The SN error code is for a Non-functional High temperature sensor which automatically kicks the heater off and trips the breaker. You can purchase new sensors for $75-$85 (it could be more, my pricing index is quite a few years out of date) I'm not sure where the sensor is located in that particular tub, although it is most likely in the heating canister. Make sure the power is off at the breaker before attempting any tub repair. if you have shut-off valves to the heating canister you may not have to drain the tub, remove the heating can and replace the sensor you will have to plug/unplug the sensors from the power pack/circuit board. I hope this helps =)
Oct 27, 2013 | Pool & Spa
Daily air clean out happens in the middle of the night
With Air Tubs there is usually a setting on the control that will allow you to set the time when the purge cycle will come on or it to set it when you are done using the tub like maybe 10 mins after the control is shut off.
Rod
U S Parts Center
888-521-6183
Mar 17, 2013 | Neptune Tao Tub - Model TAO3666A
I own a 91 F150 custom with a EFI 5.0 and when i first start the engine its runs fine after a few mins u can hear it torque up and down and once i shut if off after running it for a few mins and come
Not all of your story was printed. If the engine "hunts" for base idle, it could be caused by a dirty throttle body, a vac leak, or a faulty idle air control valve.
The computer controls idle speed by how much air gets into the intake thru the control valve.
Dec 15, 2012 | Cars & Trucks
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
;turn coleman hottub on - flashes "pr" for a few min. then it shuts off
If your Coleman has Balboa electronics 'PR' is to notify you that it is in priming mode.
It could also be your pressure switch. On most tubs the pressure is mounted on the heater. If this switch is not reading correctly it could shut the spa down to prevent heater overheating.
Sep 18, 2012 | Pool & Spa
Code for the huayu universal remote operation on toshiba tv
Hi, Here are a list of the codes for the toshiba TV, Just try them until you find one that works all the functions.
433, 434, 000, 007, 008, 014, 015, 016, 027, 028, 030, 033, 053, 056, 079, 089, 090, 091, 160
Hope this is of some help
Oct 25, 2010 | Televison & Video
Arctic Above Ground Rugged Mesh Winter Cover Pool Size: 18' X 40' Oval Armor 8 Yr Warranty Logo
171 people viewed this question
Top Arctic Pool & Spa Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
Bill Jordan
Are you an Arctic Pool and Spa Expert? Answer questions, earn points and help others
