Question about Kenmore 64992 Electric Dryer
Circut breaker turned off and turned back on machine will no longer turn on.
    Novelist:
    Champion:
  • 219 Answers
Be sure you have 220 volts at the outlet. If you do check voltage on the power cord inside the machine. Be sure the timer is set correct and check the start switch.Does the motor run? If the motor runs and the drum don't turn may be the belt broken or slipped off the pulley. If motor don't run check voltage to motor if you have voltage most likely the motor is bad it can be checked with an ohm meter. Last resort could be timer. Hope some of this helps.
Posted on Jan 02, 2011
Just replaced a bulb now have no power at all
Depending on age of home you may have a spark arrestor circut.
if you used incandescent bulb and it failed ( reason you changed ) it could have trip this circut breaker on main panel ( usually will have green toggle ). Turn breaker to full off then turn back on.
Sep 30, 2016 | Hardware & Accessories
Trips breaker
I would suggest looking at the heating element for current leakage
Apr 04, 2014 | LG WM2655HVA 3.6 Cu. Ft. Graphite Steel...
Hello, after the first fill it will trip the circut, I have tried what I believe to be a different circut with the same result. Washer still full of water, please help.. Thank you for any help. Model# ...
Check to see if this may be caused by a Ground Fault Interrupter. If water has gotten into the electrical system of the machine, this will continue to trip until the fault location has dried out and no longer causing electrical leakage. If this is a standard breaker that is tripping, this would mean you have a shorted motor causing it to draw excessive current.
The combination breaker/GFI can itself fail; I replaced several of these after only a few years of service.
Aug 08, 2011 | Whirlpool Washing Machines
After installation dishwasher will not turn on
Have you checked the 115 volt outlet for power?
Did you turn off circut breaker prior to install?
Or is circut breaker on?
If unit is hard wired in re check your connections and wiring.
Possible shipping brackets not removed.
Jan 16, 2010 | Dishwashers
Vacuum stopped working due to clog. Clog cleared vacuum won't turn on
There is a reset button on the back of this machine that acts as a circut breaker. Push that back in and it should go.
Nov 26, 2009 | Hoover Elite Rewind Bagless Upright...
I have a Homeline Load Center circut breaker Catolog # HOM48l125GRB, which was installed for my spa. Each summer the spa is drained and the circut turned off. I turn it back on in the fall. However, this...
You have 1 of 2 problems #1 the breaker overload element is bad=replace breaker, #2 You have a shot somewhere in your line feeding your spa, make sure you have power to the line side of your panel/breaker. hope this helps you...
Oct 03, 2009 | Square Homeline Circuit Breaker
Was welding 10 min later mach. quit power was good circut breaker was good and fuses were good
it probably has a fuse for overheating safety, or else the feed motor fried
Apr 24, 2009 | Welding Tools
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My saw wont run only buzz
Sounds like teh capacitor has blown. These machines use normally use induction motors so they need the capacitor to take a charge and give the motor a kick in the right direction. You could CAREFULLY turn the machine on and spin the blade by hand. If it runs now then you will need a new capacitor.
Oct 14, 2008 | Saws
Kenmore 64992 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
