Question about Hitachi Televison & Video
My Hitachi Plasma 32PD7800TA won't turn on. There is no red light that is usually displayed. I have made sure it is turned on at both the wall and the tv. I also checked the power cable by plugging it into something else, and it worked, so that is not the problem.
The power supply pcb is dead. Possibly the CPU pcb. Probably not worth the repair cost !!
Posted on Jan 11, 2011
Tv turns on but stays on standby
Have you checked the manual? Here is a link http://www.manualslib.com/manual/419601/Hitachi-42hds69-42-Plasma-Tv.html
May 15, 2016 | Hitachi 42HDS69 42 in. Plasma Television
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I have a Hitachi 50"
Hello mark riazzi,
I am not sure what you mean by a box that came with the tv. What is the model of your number of your tv? Some tv's have power right at the front of the tv and the other buttons are usually located on the side of the tv or if its a thin tv, then on the back at the edges. You should have also gotten a remote with the tv if it was new out of the box. If not, get a universal remote. The manual that comes with the universal remote will have a code for the model of your Hitachi tv. Follow the instructions and you can use that remote instead. Good luck.
-Joe
Aug 29, 2011 | Televison & Video
I have a hitachi 55pma550 plasma tv.when I turn on the main switch red light comes on standby. But when I turn on tv the red red light on stand by turns green only for 10 seconds and goes red no picture...
It's most likely the smps. You'll first need to check voltages at CN63, pin #1-(+5v), 3-(+3.3v) and pin 8-(+6v) Also check CNPPS, pin 1-(+30v), 4-(+5v), 8-(+12v), 12-(+10v) absent these values and the power supply is clearly the problem.
Jun 30, 2011 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
Hitachi Plasma HDTV turns off by itself. indicating lamp flashes.
The unit senses a fault in the power circuit. It is either in the power supply unit (PSU) peripherals or in the PSU itself.
  • One of the peripherals might be loading down the PSU causing it to shutdown.
  1. Check the power input terminals of the peripherals for any short circuit using an ohmmeter.
  2. Replace any part found to be causing the issue.
  • The power supply unit cannot run under load and shuts down. It is usually caused by bad capacitors.
  1. Check the PSU board for any bad capacitor.
  2. Replace bad capacitors with the same specifications.
  3. Make sure to replace the capacitors in correct polarity.
  4. Bad capacitors look like these:3a72a3c.jpg17dffa0.jpg
Nov 03, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 32HDT20M Plasma Monitor
What are the Temp and Lamp indicator lights doing?
Dec 31, 2007 | Hitachi 32HDT20 32 in. Plasma Television
Televison & Video Logo
160 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
