Question about Intermatic T104 24h 208-277v Mechanical Time Switch
Is Intermatic T1000R4 time swith mechanism fused?
The only fuse protection on T104R indoor-outdoor timer comes from circuit breaker box.
You can add in-line busman fuse by drilling 1/2" hole in side of T-104 box.
http://waterheatertimer.org/Fuseholder.html
http://www.grainger.com/Grainger/items/1CV90?Pid=search
Posted on Jan 03, 2011
Where are the fuses located?
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
Open door on control center, and push breakers fully off and then fully on
Use manual override lever located on each timer to see if pump can be manually operated
Gene
Sep 01, 2014 | Intermatic T40004R - Pool-Spa Control...
Intermatic timer instructions
http://www.intermatic.com/~/media/Intermatic/Documentation/Time%20Switches/Mechanical%20Time%20Switches/24%20Hour/T100%20Series/T101%20Instructions.ashx
Aug 01, 2014 | Intermatic T101 - 24 Hr. Dial Time Switch...
I have an intermatic model t106m pool timer switch that has stopped keeping the time. I have checked the breakers and find nothing tripped. The swith can still be manually turned on and off. Please...
Open following link for T106 240volt troubleshoot and repair steps.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Timer is probably repairable if manual override clicks crisp and clean and load turns on-off.
If the timer dial is not rotating or not on time, then replace clock motor. WG number is printed on clock motor.
If dial is rotating on time, then replace 156T1978A trippers.
Jul 03, 2011 | Solar Intermatic Single Pole Model Ej341c...
I have intermatic t104 time 24 hour, the door hinges are broken can i get new door.
Page below shows Intermatic boxes, but doesn't describe which timer fits which box.
And the box costs as much or more than new timer.
http://www.electricsupplyonline.com/prod/intermatic-timer_accessories.php
Amazon sells T104 indoor
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88/ref=pd_cp_hi_3_img
T104R raintight sold at Aplus
http://www.aplussupply.com/intermatic/timer.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | Intermatic T104 24h 208-277v Mechanical...
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
http://waterheatertimer.org/pdf/Woods-59200.pdf
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
The dial on the intermatic water heater timer is not rotating on it's own and is easy to turn in either direction-without pulling it out and setting the time. The unit is only 1 year old..Can I replace the...
You can replace clock motor on many Intermatic timers:
Snap mechanism loose using metal spring top inside box.
Tip mechanism out and get clock motor number off motor.
Google search specific clock motor number.
Aplus sells many clock motor:
http://www.aplussupply.com/intermatic/timermotors.htm
Electric supply online sells clock motors
http://www.electricsupplyonline.com/prod/intermatic-motors.php
Grainger carries inexpensive clock motors for T101, T103, T104 timers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
T101 and T103 use 125v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
T104 uses 240v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
Dec 01, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I need the instruction manual for Model # R8806R101C.
Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
R8806R101C manual is not shown on Intermatic, even among discontinued models.
But product is still for sale.
R8806P manual is available:
I suspect manual is very similar since it's a mechanical time piece. If not, then add a comment with specifics and I will help.
120V:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8815p101c%20-%20english.ashx
240V
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
R88 series sprinkler timers: click model number to see manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Nov 22, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How do I reset the time needle on my intermatic modle t101 The screw was loose and the needle move so
T101 Intermatic is 120Volt electro-mechanical timer
Silver pointer is located at 6:00 position.
Tighten the center screw with star screwdriver
Lift and rotate yellow dial until current time lines up with silver pointer.
How electro-mechanical timers work:
Place ON-OFF trippers on dial.
Trippers rotate around with passing time.
Trippers encounter on-off lever.
OFF tripper clicks lever one direction.
ON tripper clicks lever other direction.
Manual override lever clicks back and forth each time on-off lever is clicked.
How to wire T101:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 16, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Intermatic T104 24h 208-277v Mechanical Time Switch Logo
116 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
