Question about Keurig B60 Coffee Maker
When i put the k cup in , just clear water comes out and not a steady stream but dribbling all over the place, also there is a grey holder that come with the coffee maker, what is the holder for?
  • erniesangrey Jan 02, 2011
    YOU DIDN,T ANSWER MY QUESTION DO I HAVE TO SPEND MORE MONEY TO MAYBE GET A SIMPLE SOLUTION TO MY PROBLEM
  • erniesangrey Jan 09, 2011
    O.K THAT ANSWER ONE QUESTION HOW ABOUT THE OTHER QUESTION WHEN I JUST PUT IN THE K CUP ONLY CLEAR WATER COMES OUT NO COFFEE, AND IT THE WATER DRIBBLES OUT NOT IN A STEADY STREAM
  • 355 Answers
The gray holder is for using your own coffee. you do not need it using the k-cup. that is most likely your problem. use the k-cup without using the gray holder
Posted on Jan 07, 2011
How do you purge a keurig coffee maker and establish the hot water reserve
With the water container in place, put a container under the nozzle and lift the handle as if you were putting in a K cup. Close it and push the brew button. You may have to repeat this a few times to get all the air out. Once you get a steady stream, you're done.
Feb 08, 2017 | Keurig Coffee Makers & Espresso Machines
Why does my Keurig smoke when brewing coffee, and the water doesn't go through until I take out the cup?
You probably have a clogged nozzle/needle. Take a straightened paperclip and run it thru the hollow needles that puncture the top and bottom of the k-cup. Make sure they are clear then try to brew a cup. Never reuse a k-cup. That's what usually clogs the needles.
Sep 19, 2014 | Keurig Coffee Makers & Espresso Machines
Water leaking not just comming out of spout
Sounds like your water outlet is clogged. Open the head and push up the cup holder to remove. When out, clean out the tube at the bottom of the holder with a paper clip or something similar (I use a cake tester - long skinny metal rod. This will clean out any clogs in the output path. Also remove the bottom part of the cup holder and clean it too. Put back together and place back in brew head the way it came out. (Caution - some models you have to twist the cup holder to remove, and some it just comes straight out). There are many you-tube videos that will show you this also.
Mar 27, 2014 | Keurig Vue Brewing System
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
The water or coffee does not come out correctly anymore. When making a cup of coffee (w/ pod) or just hot water (no pod), the hot liquid does not come out in a steady stream, it goes everywhere. When i...
211333Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
I broke the peice that puts water through the coffee basket on a Keurig Elite B40 Coffee Maker where can I buy parts for this?
If you are talking about the K-cup holder that punches the bottom of the k-cups, they usually are not for sale, and you can only find them on ersale sites like Ebay.etc...
you could also go buy a "Keurig My K-Cup Reusable Coffee Filter"
and just use the main grey plastic filter holder... but you will have to puncture the bottom of the k-cups yourself before dropping them into the holder...
You wont need the filter basket or the lid if your using k-cups... just the filter holder...
dont forget to punch a hole in the k-cup first...
May 14, 2010 | Keurig Elite B40 Coffee Maker
I have a Jura S9A that is about 2 years old, brewed about 1600 cups. Regular filter changes/cleanings. When I brew a coffee, it dribbles out, but makes a full cup of coffee. It also has trouble getting a...
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
Oct 10, 2009 | Jura Capresso Impressa S9 Coffee...
I have to hold the filter when making coffee - if I don't the filter holder starts to unwind and then coffee and water spurts everywhere. It has only just started this and I clean it constantly making...
Please check the following:
1. Hooks - the hooks could be worn
2. Gasket - it could be worn or broken.
You need to replace the filter holder or the rubber seal/gasket.
Hope it helps and have a great day!
Jun 16, 2009 | Coffee Makers & Espresso Machines
Keurig B2000 only dispensing 1/8 cup of water
Hi If you are still having problems with this machine Email me at kinshella@shaw.ca
Apr 25, 2008 | Keurig B60 Coffee Maker
B-50
the needle in your k-cup holder is broken and over presure built up in the k-cup, and create security stop. Change our k-kup holder. if the needle is still in place the k-cup must be puncture on both side on top and bottom. if is right our needle can be block. clean with a little rod of stainless steel.
Nov 03, 2007 | Keurig B50 Coffee Maker
Keurig B60 Coffee Maker Logo
81 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
