Question about LG Computers & Internet
I have LG my PC, it makes a humming noise when switched on and display does not come
    Problem Solver:
  • 20 Answers
It could be the battery needs to be replaced . If not , I would take it to a repair place and have them check it for you . They will usually check it for free an then tell you how much to fix it.
Posted on Jun 27, 2014
Should motor make humming noise - instead of making no noise - if starter Capacitor is the only thing faulty ?
Not always, just replace the cap to start with. Sometimes they howl an other bearing make a noise.
Jul 23, 2017 | Cars & Trucks
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
Lg dle2101w is making a loug hum and rattle but works fine
the hum is usually a bad motor? perhaps u hear what u think is a hum? the rattle can be due to bad bearings, for example transmission spin bearings, tub thrust washer bearing, loose belt or worn belt.
Mar 08, 2015 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
My LG refrigerator model # LFX25960ST/bottom freezer, is making a humming noise that stops when we open the door. What is it?
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
Sep 25, 2010 | LG Refrigerators
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
May 15, 2010 | LG DLE2512W Electric Dryer
The motor has gone bad on your dryer...
Here is a tip I wrote about your problem....
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 28, 2010 | LG DLE2512W Electric Dryer
Lg refrigerator LFC22740ST loud humming noise no
You have a bad fan motor ... replace motor.
Nov 11, 2009 | LG Refrigerators
High pitched noise
HI Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.
The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
Oct 07, 2008 | Hoover HDC6 Electric Dryer
Computers & Internet Logo
20 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
