How would I go about hooking up the dvd & vhs player to converter box to television?
  • 50 Answers
Use RCA plugs, the ones that are red, white and yellow. Connect from the output jacts on the players to the input jacks on the back of the tv. yellow video out to yellow video in, red to right audio out to audio in on the tv, same for left audio out to in of tv.
Posted on Jan 02, 2011
DTV converter box needs specific channel
My GE tv, an older model, no longer works on channels 3 or 4 while hooked to my DVD/VHS player. I have to set my tv to channel 91 and I use the player to change channels.
Jan 28, 2009 | GE 25GT240 25" TV
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
I want to convert a DVD to a VCR tape.
Do you want copy dvd movie on VHS tape?
Use DVD/ VHS Combo Player like shown in below picture...
Oct 27, 2008 | Televison & Video
Digital converter box hook up
Can you describe how the DVD and VCR were connected prior to the converter box when they were working? I need to know that in order to guide you properly.
Thanks,
Dan
Jul 24, 2008 | Philips Magnavox 20MT133S 20" TV
Daewoo dvd install
  1. Be sure that your VCR is a newer one with at least one "line in" set of jacks in the back. Some have one in the back and one in front.
  2. Your DVD Player should have a video/sound cable with 3 connectors on each end. Otherwise get one or 3 single cables.
  3. Connect DVD Video Out to VHS Video In (yellow).
  4. Connect DVD Left to VHS Left (white).
  5. Connect DVD Right to VHS Right (red).
  6. Turn on your DVD and VHS.
  7. Your VHS should have a tuner setting for "L1" or "L2". Select whichever shows the DVD's video on the TV.
  8. Remember to select that input channel whenever you want to watch the DVD.
  9. When watching a DVD, if you have a blank VHS in the VCR, you may record what you are watching onto the VHS, just as if you were recording from cable.
Verify these steps and you should be good to go ;)
Apr 19, 2008 | Daewoo DVDS151 DVD Player
Digital Converter Box
# 1. Why are you using a digital to anaolg box when you only have a analog signal coming in? The box is designed to see digital information then converting it back to analog. Please explain further what you are attemping to do?
Mar 28, 2008 | GE 19GT270 19" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
