Question about Kenmore 15899 Built-in Dishwasher
My Kenmore dishwasher (model 665-16032401) will not drain after completing full cycle. When I press the drain button the motor hums only. What should I do?
  • 50 Answers
Check for obstructions in the drain hose and where the drain hose drains under the sink. Check the drain in the bottom of the dishwasher. There is a filter there that can get clogged.
Posted on Jan 02, 2011
Sears kenmore elite dishwasher does not drain completely
Look at the control panel and you will see a button that says "Cancel" and "Drain" Press the button after the wash cycle has completed and the machine will drain completely.
Dec 28, 2016 | Kenmore Dishwashers
Runs full cycle but not draining
Your drain pump or drain line is most likely blocked. When you press "cancel/drain", listen for the humming of the drain pump--it can be hard to hear, especially on the newer "super quiet" models. If the motor is humming, 120v is getting to it and that means the main board is functioning. If you don't hear anything, you'll have to check at the drain motor for broken wires, or, using a meter on a low resistance setting(POWER TURNED OFF, WIRING HARNESS CONNECTOR DISCONNECTED FROM PUMP, check across the coil of the motor for an open(break) in the coil which means the drain motor will have to be replaced. Also, CHECK THE FILTER FOR CLOGS! Dishwashers are notorious for getting broken glass, food pieces, etc stuck in the drain pumps or drain hoses leading to the sink or disposal. On certain makes/models, there is a "drain break" clipped to the side of the dishwasher(to prevent backwash of dirty water back into the tub) that can get clogged or have a nasty mold/mildew build-up which can clog it.
Aug 18, 2015 | Candy Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Fills, doesn't pump to sprayer, drains on drain only cycle
Sounds like there is still something in the pump. I am 99% certain this unit has a reversable motor.
Jan 26, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Aug 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Oct 29, 2007 | Dishwashers
Does not appear to wash
is there a low humming noise when it should be washing? if so may be the motor capacitor
Apr 02, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 15899 Built-in Dishwasher Logo
268 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
