Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a westinghouse super capacity plus commercial washing machine. It spins on some washers and now has a burning smell to it
    Novelist:
  • 116 Answers
Unplug it and don't use it will be a burnt wire or the motor burning out there is a safety feature built into it which will cut the motor off after it gets hot so it wont start a fire. You will need a qualified technician come look at it and replace one or both sorry for the problem its giving you. Also if it is the motor they normally run $150 and up...
Posted on Jan 06, 2011
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Nov 01, 2007 | GE WJSE3110A Top Load Washer
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Washing Machine does not drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Westinghouse WWS833ES Super Capacity Top...
MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
I just replaced the belt on my White WESTINGHOUSE la 560axw2 WASHER. It is now severely out of balance whenever it reaches the spin cycle.
The problem may be with the top springs may be damaged you can replace the spring set completely to get the smooth running in the spin
Dec 30, 2009 | Westinghouse WWS833ES Super Capacity Top...
Whirlpool super capacity commercial washing machine
Sounde like a bad lid switch . With no model number , can't help you further .
Sep 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Apr 12, 2008 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
