Question about Kenmore Refrigerators
Water has shown up bottom of bins bottom of refrigerator
  • 472 Answers
A few things to check if you have a moisture control button or setting try that... is this a top bottom refrigerator not a side by side could be a problem with the freezer drain in the top of unt plugged and causing unit everytime on defrost to allow water to spill over and go down refrigerator you would eventually see ice build up in freezer section if this was the case... if this unt has a water in the door feature sometimes they put a water storage tank in the refrigerator side to keep the water chilled when you get it out of the door make sure you have no leaks in this system... hard to give all the possibilities not knowing what style you have but here are a few suggestions to start you out good luck
Posted on Jan 02, 2011
WATER IN THE BOTTOM OF REFRIGERATOR
get model # to be accurate. but if freezer on top and u get water in fresh food compartment under crisper bins u got blocked defrost drain. as much as i can help with such little info.
Mar 27, 2014 | General Electric Refrigerators
I have a frigidaire refrig. Water collects under the fruit and veg bins. Any ideas why and what I can do would be helpful. It is not coming from the ice maker as it was doing this well before I put the...
Hi Erica, I am happy to assist you. I understand that water is collecting in the bins. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator bins. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
I certainly hope this troubleshooting tip resolves your concern. If you have any additional questions, please feel free to respond.
Aug 16, 2013 | Frigidaire Refrigerators
Refrigerator leaking water
You gave no manufacturer name or model number so this is only a guess: If you refrigerator is a self defrosting one, it will periodically, allow ice building up in it to turn to water which naturally drips to the lowest point. Most refrigerators have a drain below the vegetable bins on the bottom. That is probably where the water is coming from. Solutions include putting a shallow baking pan under the bins or under the refrigerator to catch the water, then empty it periodically.
Jan 21, 2013 | Refrigerators
How do u replace water filter on samsung refrigerator side by side model number rs2630sh
The water filter in the extra space behind the vegetable Bin.
1) As shown, the fixed cap separates from the refrigerator by rotating
it counterclockwise.
Remove the water filter from the box and put a month indicator
sticker on the filter as shown on the next page.
2) The water filter should be replaced every six months, so if the filter
was installed in March (for example), put on the "SEP" sticker
to remind you to change the filter.
3) Remove the protective cap, then position and insert the
filter as shown.
4) Slowly turn the water filter clockwise 90º to align
the indication mark on the cover, locking the filter in position.
Or go here bottom of page 24 top of 25.
http://www.azmanual.com/download/21949/5478c9cd79f4e04b6a2f6e2b4ab9f513/
Please rate 4 thumba for the free answer.
Mar 08, 2010 | Samsung RS2630WW Side by Side Refrigerator
Ice buildup in vegetable bins - otherwise OK Not model shown below (top freezer, too old) but listing one only way to get past screening
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Water is collecting in veggie bins in
I can solve your problem for you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
Jul 11, 2009 | Refrigerators
Water pooling under my express thaw bin in bottom of refrigerator
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water from dispenser while your checking (Might only leak when water dispenses
Mar 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
