Question about Vivitar ViviCam 8025 Digital Camera
MSDC error message on my camera and i just bought it
Camera, the charger cord broke, got a new one, not sure if it's charging cause it always shows the MSDC on the screen when I turn it on. What has happen to my camera? It is a Vivitar ViviCam x029
Are you charging it by connecting to a computer? The MSDC message says that the camera is connected to a computer. What happens if you disconnect it and then turn it on?
Oct 14, 2016 | Vivitar ViviCam X029
What does msdc mean
Mass Storage Device Class: http://en.wikipedia.org/wiki/MSDC
If your camera is saying this then it's either connected to your computer or thinks it's connected. With most cameras this is not an error but simply a notification that the camera is connected and can be used as a storage device but not as a camera.
Jul 14, 2014 | Cameras
What dose MSDC mean
Jul 14, 2014 | Vivitar ViviCam 8025 Digital Camera
Msdc message when plugged into outlet
You may be doing everything right, but the battery may not be charging at all
Jun 29, 2013 | Vivitar ViviCam X029 Digital Camera
Vivitar 8025 comes up with msdc in blue when connected to my pc via usb any solution
MSDC just means Mass Storage Device Class which is the protocol used to connect your camera to the computer over the USB lead. It is not an error message, your camera is just telling you that you are connected to the computer.
Open "My Computer" and look for a new drive under "Devices with removable storage". You should see one that represents your camera's memory. Click on it to open it, then on the folders within it until you find some pics, which you can then drag and drop to your desktop.
Jan 15, 2011 | Vivitar ViviCam 8025 Digital Camera
How i fix msdc write sector error in memory card..........
sir i have a 2gb memory card but its not be deleted then i try to delete this , after loading show this message MSDC wright sector error, & then moved any file then show this message "access denied" please help me.
Dec 17, 2010 | Electronics - Others
I get a MSDC message when I plug the camera in to charge
If you're plugging it into a USB port on a computer, then it's perfectly normal. The MSDC is merely telling you that the camera recognizes it is connected to a computer.
Nov 07, 2010 | Vivitar ViviCam 8025 Digital Camera
Msdc not present
MSDC error indicates a file system related error. More often than not it is caused by corrupted file system on the memory card. However it can also occur due to faulty in built memory. To find out which one it is remove the memory card and see if the problem persists and let me know your observation(s).
Sai.
Mar 08, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Turned the camera on but screen display says MSDC and can turn not camera off
Make sure the battery is inserted correctly. We spent 5 hours complaining about the camera we bought for our daughter because we couldn't get rid of the MSDC message. We had put the battery back in it upside-down after inserting the memory card; she is the one who discovered our mistake.
Dec 25, 2009 | Vivitar ViviCam 8025 Digital Camera
Msdc
i have the same camera and the same problem but i have found out msdc means mass storage device, for the camera to work you have to have a memory card inside it. im getting one tomorrow for mine, so hopefully that should solve the problem :)
Vivitar ViviCam 8025 Digital Camera Logo
236 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
