Question about Maytag Refrigerators
My refrigator doesn't cool. the compressor clicks on and then goes off. what could be my problem?
  • 472 Answers
Most likely you have a bad start relay and overload on the compressor is tripping compressor out... i would try that first.... it is possible the compressor it self has failed but if you pull the relay off and it rattles inside most likely get a new one and your back up and running again...
Posted on Jan 02, 2011
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Refrigerator and freezer not cooling
Check the start capacitor on the compressor and the thermal cutoff switch. It is where the wires connect to the compressor.
Jan 05, 2014 | Whirlpool ED5VHGXM Side by Side...
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
French 3 door LG refrig.. Not cooling but compressor acts like it wants to kick on. The other guy said it was something wrong with my defrost cycle/ The refrig is defrosted but when plugged back in it is...
You either have a defective start relay or a defective compressor.
If it is clicking every 45 seconds or so,you can try a new start relay.
Feel the compressor.
Is it hot to the touch?
Is the compressor fan motor running?
Apr 06, 2011 | LG Refrigerators
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Kenmore 795 refrig is not cooling sounds like everything is running but no cooling. took back panel off and hear a click then a electrical sound which goes for under a minute then shuts off
That indicates that the compressor is overloading the wiring. That clicking noise is the thermal breaker. The freon could be low. causing the compressor to overheat, or the compressor itself is deffective.
Nov 25, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
My refrigerator dosen't cool or freeze
the hot piece is the compressor.the clicking is the relay trying to start the compressor.generaly when im out on a service call and the compressor is hot and relay clicking the compressor has failed internally.because if the relay was clicking but the compressor was not hot there was a chance only the relay was bad and not allowing power into the compressor.but because the compressor is hot that tells me the relay is letting the power to the compressor but the compressor cant do anything with it because it locked up and its absorbing that power getting hot and then clicking on overload you could try a relay but i don't think it will help. God bless ,tom
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
48 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
