Question about Whirlpool Washing Machines
Insufficient instructions on programming wash cycles
  • 2 more comments
  • mankelow Jul 09, 2008
    Not sure where to put settings for regular cold wash. If I put it on 30deg cotton the clothes are quite wet at end of cycle so am re spinning on spin setting on other side of dial. HELP!!!!!!!!!!!!!!!!!
  • mankelow Jul 10, 2008
    Model number WFS1071AW Couldnt figure out what you get as far as program goes when you select an option on dial.
    e.g How do I get a regular cold wash with a decent spin. A bit thick aye
  • mankelow Jul 17, 2008
    Thanks dutchman you're a gem. I can see what to do now. The machine is brand new so filter shud be fine but I will keep an eye on that now I know.
    Cheers
  • eric bosman
    eric bosman May 11, 2010
    ?model number would be helpful
  • 487 Answers
HERE you can download your user manual.
As far as I can see select cotton with ## 30 degrees or wool .
What you can do is select the extra rinse cycle too .
Please also make sure your filter is clean as that will decrease the spin cycle effect
Posted on Jul 10, 2008
  • eric bosman
    eric bosman Jul 10, 2008
    please give me your model number
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
How do I distinguish between the numbers on the program guide ie- My instruction manual guide starts with program 1_90; 2- 60 etc until it gets to 9-40 mixed wash, then it goes to 1-60; 2-50.
The first part of the number is the wash cycle which will correspond to the cycle selector, the second part of each number is the selected wash temperature
Jun 14, 2016 | Washing Machines
My washing machine model no ewf 1421,is writing e60,why
Insufficient heating measured by the main board during washing cycle and also during drying cycle at washer-dryer.
Could be faulty: heting element, pressure switch, NTC sensor, printed circuit board (PCB),
wiring between PCB - heating element,
wiring between PCB - NTC sensor,
wiring of pressure switch.
Dado
Nov 20, 2014 | Electrolux Washing Machines
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
DETERGENT
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount. Nearly all brands of "HE" detergent have incorrect instructions. The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Sensors
7) Reduced Spin Speeds (laundry not spin-dried effectively)
These washers MUST have the right amount of the right stuff or they simply will give you lots of grief. The program can sense suds. It cannot pronounce your wash clean if it thinks their are suds. So it try's to fix the problem and ends up overworking itself.
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher wont start washing but start light is flashing 11 times
hi...
The cause of the problem is an insufficient rise in water temperature during a pre-set time period. The heater fault-detection program that was added to the electronic control is designed to shut down the dishwasher if the board-test for proper water temperature rise is not sufficient.
The dishwasher run cycle was modified to add 8 minutes 45 seconds of heat at the beginning of the main wash cycle. If the inlet water at the thermistor is below 110°F, the thermistor looks for a water rise of 4°F. If the inlet water is over 110°F, the test is for an increase of 2°F. If the temperature rise is below specifications, the unit will drain and the clean light will blink seven times.
You will need to identify possible causes of insufficient temperature rise. These causes may include checking the wiring to/failure of the control, the heating element, the thermistor, the inlet valve, door switch, motor or capacitor. Make sure that water is not siphoning during fill. Once the heater fault detection is triggered and the condition resolved, the electronic control must be reset by initiating a special diagnostic cycle. Use the Product Tech Sheet shipped with each dishwasher — you’ll find it behind the kickplates — to identify the correct cycle sequence. The rapid advance cycle will not properly reset the electronic control....
thank u
rate me
Jul 22, 2009 | Dishwashers
Instruction manual
Option B is the standard option for whites and colors and is approx 125 mins long. Option A adds a 25 min soak. Option C/D is the short cycle at 70 mins. I haven't figured out how to program an extra rinse yet.
Apr 18, 2009 | Washing Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
