Question about Xantrex Technology Xantrex Prosine 2.0 Inverter/Charger with Remote Interface 2000 Watts
I have 0 output on the 120 volt a/c I shut it off to cool down still nothing. cooling fan don't run. 12 volt fuse is ok [2]. took cover off to see if i can find a smaller fuse,none Is there a repair shop in los angeles,cal?
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: my 2000 Fleetwood Discovery Motorhome
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
Electrograph 47-in monitor. Why does it have a multicolored vertical line running down it?
The cooling fans not running would definitely cause a problem with overheating. But the question is, did the fans fail or is there a problem with the power supply that is causing the fans not to work and also interrupting proper operation of the video boards. It is more likely a power issue than 2 failed fans. If you have a multimeter you can check the power coming into the fans. Most will be 12 volts, some might be 5 volts, usually stamped right on the fan.
May 24, 2015 | Computers & Internet
Outlets not working all fuses are good
120-
VOLT
AC
SYSTEM
The following electrical components (if so equipped) will only operate when your
RV is connected to shore power: 120 to
12-volt power converter, air conditioner,
120-volt refrigerator, microwave oven, television(s), fireplace and appliances
plugged into convenience receptacles.
SECTION 6 - ELECTRICAL SYSTEM JAYCO TOWABLE
6-2
120-
VOLT
CIRCUIT
BREAKERS
The 120-volt AC circuit breakers located in
side the main load center protect all
120-volt wiring and components in the RV fr
om circuit overloads and short circuits.
Should a circuit overload or short circui
t occur the circuit breaker protecting the
affected circuit will "trip" preventing the flow of electricity through that circuit.
If a circuit breaker trips, shut "off"
the appliance on that circuit (i.e., power
converter etc.) and allow the circuit breaker to cool down for a brief period of time.
After the cooling down period, reset the circuit breaker by moving its lever "off" and
then back to the "on" position. If the circuit breaker re-trips or frequently trips,
contact your dealer to have the electrical problem diagnosed and repaired.
A circuit breaker identification label is permanently attached to the inside surface
of the 120-volt load center.
Maintenance and Replacement
At the beginning of camping season, inspect the circuit breakers and replace as
needed. Test by turning each circuit breaker "off" and back "on". Circuit breakers
are wearable parts and must be replaced
as needed, as part of your RV
maintenance. If you have any questions, consult your dealer.
Please contact your dealer for repair assistance when replacing circuit breakers.
CONVERTER
The power converter converts 120-volt AC power to useable 12-volt DC power
when the shore power cord is connected to an external power source.
The converter has a built-in protective thermal breaker that will shut it down should
overheating occur. Overheating can be
caused by operating the converter above
its maximum power output for an extended period of time, or by an obstruction to
its ventilation air flow. To reduce converter heat build keep unnecessary 12-volt
lights and motors turned "off"
Keep the converter cooling fins and fan clear of
obstructions.
Inspection and maintenance
If the 12-volt power converter is not working (auxiliary battery not being charged)
check the reverse polarity fuse(s) in the converter fuse panel.
There are no
customer serviceable parts inside the converter case and the
manufacturer's warranty will be void if
the case has been removed
. If you
have further concerns contact your dealer.
Nov 16, 2014 | Jayco 2013 Jay Flight Swift 264BH
1997 Lincoln Continental STILL overheating, have tried lots of things! New Radiator, new thermostat, checked thermostat housing, new hoses, hose clamps are fine, head gasket ok, waterpump ok. I can go into...
Candy,
The only way for you to use the heater system to cool the engine is by having the temp setting to highest setting and highest blower speed. That will then make your heater ocre a cooling device for the engine. When you turn on the a/c system, it does not cool the engine, and it shuts itself off whent he engine gets hot to protect the engine. That's when it blows warm air.
So check the fuse I talked about. and email me direct as I said. We need to run 12 volts from teh battery direct to the cooling fan. I will tell you how to make a test jumper to make sure the cooling fans work.
You have 2 relays and 2 cooling fans, and I don't think they all quit at the same time. I think they are good. but testing will tell us
Oct 11, 2011 | 1997 Lincoln Continental
I have a 2004 Pontiac Sunfire. When the car is in idle the air blows out hot and the Temperature gage rises and the car over heats. When the car is moving the air blows out ice cold and the temperature...
Sounds like your cooling fans on the radiator are not working. The fans are activated by a thermol switch on the engine or radiator reading the coolant temperature and an A/C switch. When the coolant is too hot the fans should activate cooling the system down. And, when the A/C is on the fans should also activate in order to cool the condensate so the A/C would work.
When you are driving, the movement of the vehicle throught he air is providing enough air flow to keep things cool and functional.
I would check the radiator fan fuse or fuses first. If those are OK I would try to run the fans with 12 volts and a ground that I supply just to see if the fan motor(s) actually run when powered. If the fan don't run when powered then the fans are bad and will need to be replaced. If the fans do run when you power them manually, then something is not allowing the power to activate, like a relay, control unit, or wiring.
It will take a little diagnostics, but it is not too difficult to chase it down.
May 03, 2011 | Pontiac Sunfire Cars & Trucks
My Cuisinart cwc-600 does not cool. It registers 45 degrees but is not cold enough to make white wine palatable. No matter where it is set, it seems to be a room temperature. We live in a small house so...
I have been all through these, and they are not very repair friendly. If it's under 3 years old Call Cuisinart, they will exchange it.
They are solid state cooled using a peltier chip cooler. There are 2 fans in the back cavity, and 1 inside. Remove everything from inside, and set the temp to cooling. Do all 3 fans run? If the inside fan does not run, no cooling. The fans are common 2 wire 12 volt computer fans, and available at computer parts stores that sell PC cases and components. Next is to check the cooler itself. Remove the inside rear cover. There's heatsink under the inside fan. Does it get cold when the fridge is running? If not, the next step you will need to get the back off. The Torx screws are special, but a quick slotting of the screw heads with a dremel or a hacksaw, and a regular screwdriver will remove them. Once off, note the red/black fan wires. Also see if there is a load of dirt in the heat sink. If it's plugged, no cooling. Back to the red/black wires. The fan wires are thin. The peltier cooler is heavier. Set to cool, Check for 12 volts on all 3 pairs of wires. If there's power, the fans run (inside and out) and the inside heat sink does not cool, the peltier chip is bad. It's major surgery to replace the cip, but it can be done, and there are scads of sellers on E-bay selling 60-90 watt peltier coolers that will work. They are standard millimeter square sizes, just match the thickness, 12-15 volts, and wattage (around 60-90).
If you are not getting power on the peltier cooler chip lines, there is a tiny fuse on the lower left of the circuit board. Check it.
These are not servicable from cuisinart. Even the silly screws to change the light bulb are security torx type. Fans are available at computer parts stores. Fuses at electronic supplies. The peltier chip can be had from E-bay. That circuit board is impossible to get. Any other parts are impossible to get to by the way it's built.
Jan 28, 2011 | Cuisinart Private Reserve CWC-600 Wine...
Wont cool down fans in the back of the unit constantly run
Remove the back.
Remove the fans. See of the heat sink is not plugged up with dust. If so vacuum it out.
Get a dc voltmeter. Fire up the fridge. Set it to cool. With the fans running, check for 12 volts on the connector that's on the lower left of the circuit board. This connector powers the Peltier cooling chip. If you have 12 volts, and no cooling the Peltier cooling chip is bad, ir the second fuse is out. There is a small cylindrical fuse near the lower left corner of the circuit board. Carefully check for voltage across it. If the fuse is good, and the fans running, you will not sense voltage across this fuse. Bad, you will read ~12-16 volts.
If your Peltier Chip is bad, it's usually caused by over heating from a plugged up heat sink or fan stoppage. These chips are available off E-bay for ~$13, but require nearly a total tear down of the fridge to change it. 95% of these cooler chips are single layer, square, and vary in thickness. You should find one that is drop-in should you choose to 'Go for it'. Look for a 60-80 watt unit that is the same or slightly thicker, and the same size square.
Oct 22, 2010 | Cuisinart Private Reserve CWC-600 Wine...
MY BLOWER WAS REPLACED IN THE SUMMER BUT IT NEVER TURNED OFF UNLESS WE SHUT IT OFF AT THE SWITCH. NOW I SWITCHED THE TSTAT TO HEAT AND THE INDUCER FAN TURNS ON WITH THE BLOWER BUT NOTHING EKSE TURNS ON. NO...
be sure the fan setting on the stat is set for auto, not on. in this mode the fan should only run when there is a call for cool or heat.if the fan continues to run check at the control board to see if you are getting 24 volts low voltage between green and common. if you are then the stat is bad. if youaren't then your electric control board is possibly bad. a lot of gas furnaces fall into a failsafe mode when a sensor or function fails and the blowers stay on 24 7. you may well have several problems from what you are saying. if you turn everthing off and start a new cycle for heat the first thing that should fire up is the induced draft motor , then the ignotor, then the gas valve. you can check each item with a meter , generally 120 volts to the induced draft motor, then 120 volts to the ignitior, the 24 volts to the gas valve. then ignition and 120 volts to the motor. most furnaces have a heat terminal and a cool terminal on the board. common to heat should get 120 volts on a call for heat after the sequence of operationb has taken place. 120 volts should be sent to cool terminal on a call for cool. a continueous blower is a sign of a failed safety. perhaps the motor failed and the safety opened and the motor was replaced but the safety never reset?. look at all the little micro temp sensors around the burner. they are like little breakers and need to be pushed in to reset . usually like a little stem that pops out from a metal or plastic dic. some are size of a quarter, some the size of a dime.
Oct 29, 2008 | Heating & Cooling
Avanti EC15W-2 Thermoelectric - stopped cooling. Purchased on August 3, 2006.  Has always been quiet. Still is, but I can hear that something's running if I put my ear to it. Light works.  Any suggestions?...
I think the circuit board is nothing more than a power supply converting the 120 volts ac to dc. If that goes then there is no way for the solid state device to cool,
Is there dust under the back cover? Is there frost/ice build up in the fridge fan compartment. I suggest to unplug for a day and try again. Hope this helps.
Oct 22, 2007 | Avanti EC15W-2 Compact Refrigerator
Xantrex Technology Xantrex Prosine 2.0 Inverter/Charger with Remote Interface 2000 Watts Logo
27 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
