Question about Asrock P4S61 Motherboard
Show me in diagram where are connected two USB Port headers and how are connected there .
    Sergeant:
  • 223 Answers
Hi kamzaimi, just check out the tutorial i have give below so that its so easy to understand this process to connect USP port to your motherboard
CLICK HERE to view the tutorial
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 02, 2011
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
Ashley,
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
http://www.ebay.com/itm/Asus-P5P800-MX-Socket-775-MotherBoard-NEW-865GV-/221041609289?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item33771b4a49
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Point?
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&CatId=511
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
http://usa.asus.com/Motherboards/Intel_Socket_775/P5P800MX/#download
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5P800-MX/e2005_P5P800-MX_V2.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
http://pinouts.ru/Slots/USB_pinout.shtml
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
I dont know how to connect the usb port in my board
Connect the USB header to the USB pins on the motherboard.Generally the connection on the motherboard has 2 rows of pins, 5 on top, four underneath.There are 2 types of headers, 1 rectangular with 5 hols on top row and 4 on bottom. Connect to MB ensuring the holes match up to the pins. You may also have a 4 + 4 connector with 2 grounds. Connect so that the pins match up to the labels on the pins on the motherboard.ie. power, d-, d+, ground.
There are other motherboard USB configurations, but the above is for 99% of them.
Feb 16, 2010 | DFI P4M266/VT8233A (MBDF-PM10EL)...
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Location firewire input port
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Nov 01, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
Searching for a wiring diagram for my E machine....
Industry Standard Architecture exists here.
The pin arrangements for USB are standard, some usb headers are attached to the boards in the opposite direction but the pin arrangement is the same.
USB headers consist of 9 pins, arranged as 4 pins and one missing, and 5 pins like this:
x x x x o
x x x x x
these are marked as:
vcc1 usb 0- usb 0+ n/c
vcc2 usb 1- usb 2+ n/c
colours are:
red, white green black
Note: some motherboards have these connectors back to front but the connection sare as per the diagram
the audio header is arranged as follows:
X X X O X
X X X X X
top row = gnd, vcc5, mic2,n/c line
bottom row = mic1,mic r, line out,front spk r, lin out L
The cable colours may differ but the preformed plug will only fit in one place /direction
Oct 27, 2008 | E-Machines (308714) Motherboard
Front mic port and headphone
to connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
bye
rate my solution
Aug 06, 2008 | Computers & Internet
Open Questions:
Asrock P4S61 Motherboard Logo
82 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
