Question about Williams Heating & Cooling
Heater won't go on ,pilot still on ? - Williams Heating & Cooling
  • 472 Answers
Possible your not getting a call for the heat either a bad thermostat or control wire... at the unit take a jumper wire and jump the terminal labeled "r" and the terminal labeled "w" these are your power and your heat circuit see if this brings the heater on ...if it does then you have a bad control problem either with the thermostat or one of the wires going to the thermostat... if this does nothing then you may have a bad gas valve not opening the second stage post again with any questions.... good luck
Posted on Jan 02, 2011
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
Pilot won't light
if gas check for cobwebs if ok replace pilot generator
Feb 15, 2013 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Pilot light won't stay on
Dust gets inside the pilot safety during the months when it is not in use. Blow out the pilot safety without disturbing the flap. and retry.
ODS VENT FREE HEATER TUNEUP
Nov 12, 2012 | Empire ECS HearthRite HR18MN Heater
Richmond 3360 gas water heater pilot won't stay on
Open following links for pilot and troubleshooting resources:
Problem could be bad thermocouple, thermocouple not sitting in pilot flame, pilot orifice needs to be cleaned, water heater needs more air, dirty air intake, hot attic environment, backdraft blowing out pilot, or bad gas control valve.
If you get flame, then ECO is not tripped.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
http://waterheatertimer.org/pdf/How-to-replace-thermocouple.pdf
Sep 25, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
Heater won't stay lit after releasing the pilot button
The most likely cause would be a weak or broken pilot generator, also referred to as a thermocouple. It is the 'stick' next to the pilot head with a metal braided wire that separates into a white and red wire at the gas valve. Replacing it should allow the heater to start working properly.
John
Jun 29, 2011 | Pool & Spa
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
Heating & Cooling Logo
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
