My hp pavilion dv6700t laptop is working fine when i connect it in charging, but it gives battery backup time only 10-15 minutes when i unplug power.
  • 32,281 Answers
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.If the battery drops to an unacceptable chargelevel then the battery needs to be replaced.
Posted on Jan 02, 2011
I have connected the charger but the battery is not charging.It says plugged in,not charging. Is there something wrong with the battery?
If the battery is full it will display that message try working with the power unplugged for a few minutes to run the battery down and the plug the power back in, it should now tell you its charging
Mar 10, 2011 | HP Pavilion dv2000t Notebook
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
No led light when you switch on even the charge
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Please click on this link for instructions to determine the fault and fix :-
Normal 0 http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Oct 07, 2010 | HP Pavilion DV6700T Notebook PC
My laptop is not turning on
have you tried to remove the battery, try to remove it ad plug it directly without the battery
Mar 09, 2010 | HP Pavilion DV6700T Notebook
HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Feb 27, 2010 | HP Pavilion dv5000z Notebook
Battery would only last 5 min. after unplugging but now says plugged in but not charging...Time for a new one? 2007 hp pavilion
Run a battery check. For this go to desktop, hit F1. In the help screen choose Power and Battery. Go to Battery check.Connect your power supply and run the test. It will give you the status of the battery.
Nov 27, 2009 | HP Pavilion dv6000z Notebook
Laptop will turn on but screen will not come on
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 25, 2009 | HP Pavilion DV6700T Notebook PC
HP ZD8000 won't power on
have you tried this with the battery removed from the laptop?
Oct 02, 2009 | HP Pavilion zd8000 Notebook
For knowing warranty period
its time to replace the battery.
Apr 09, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
