My wireless button stays on orange no matter which way i slide it and i cannot connect with internet
  • 27,725 Answers
Ring your ISP internet sevice provider get them to check your modem for internet access online
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
hope this helps
Posted on Jan 02, 2011
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
I have a Hp Pavillion dv9000 series and for some reason i wont detect any type of wireless pick ups, my wireless light only stays orange and it will not turn blue no matter what i do..HELPPPPP!!
Check and see if you have turned off the radio for your wireless antenna- generally it is a key combination or a button on the side of the laptop.
Oct 11, 2010 | Computers & Internet
I have no wireless internet. It went out all of the sudden last night. This is an urgent matter as I need it for work. Resetting router does not work, cable modem IS in working order, orange light...
Just to clarify when you say your computer does connect with an Ethernet chord you mean you are able to connect to the Internet? If so, you should be able to reach the management console and reconfigure the wifi by following these steps
Else when you say you reset the router did you try to reset it to the factory settings by holding down the reset button for 30 secs as shown here?
Jun 08, 2010 | Linksys Wireless-G WRT54G Router
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
Wireless Internet for compaq Presario
Check out the wireless setup manual for your laptop here:
http://h10032.www1.hp.com/ctg/Manual/c00065819.pdf
Hope this helps!
Mar 28, 2009 | Computers & Internet
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO EXIT AND SAVE. AFTER YOU RESTART YOUR COMPUTER IT SHOULD WORK.
Mar 09, 2009 | Compaq Computers & Internet
Cannot connect to the internet wireless
make sure the wireless button switch on...just press the button once and U can see the yellow light lblinking.....
whne the last time U use the wireless?
Aug 25, 2008 | Acer Aspire 5315 Notebook
Wireless Connection
I had this problem when I first got my laptop!
I have the same brand & everything as you, so this should work.!
the speakers on the computer are on the side of the laptop, under neath the mouse pad & everything.. (there on the side where when your computer is on, theres a little light thats green, and when its charging, theres a orange light on.)
inbetween the two speakers, there are also the plug ins for headphones & microphone. to the left of those plug ins, there are two slide-able buttons. one for blue tooth, and the other for wireless. the wireless one is on the right. when the wireless is on, the button has an orange light beside it. when off, there is no light. there is an icon beside the button that looks like a pole with a ring around it.
turn your computer on & slide the button, give it a minute to search for the networks & it'll be up & running. i hope i could help(:
Aug 15, 2008 | Acer Aspire 5050-3242 Notebook
Wireless button
is the light blue at your front slide button L/H lower front - if it is orange your wifi is inactive - slide it to on. If it is selected on and light is still orange - check the device manger in control panell - if the network devices at indicated update the wifi drivers from the HP.COM website.
Jul 09, 2008 | HP nx9110 Notebook
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
