Question about Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne
I recently made a long distance move and the charging wire for my Electrolux Pronto 2 in 1 didn't make it to my new home. How do I get a new one? Thank you. Your promptness of reply will be greatly appreciated as I miss this very handy gadget. Thank you, Marie
  • 944 Answers
You can buy it separately in the Electrolux service center if you need it urgently.Please choose the are in electrolux and choose the nearest service centre.
else
buy online
http://www.bizrate.com/vacuum-accessories/oid1868374161.html
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 02, 2011
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Can I replace the hose on the Pronto 2 in 1??
The hose is not sold online at aftermarket parts suppliers but im sure you can contact them for assistance.....
Electrolux Home Products - North America
Address
PO Box 3900 Peoria, IL 61612
Telephone
1.800.896.9756
Monday - Friday 8:00 AM - 7:30 PM CST
Saturday - Sunday 10:00 AM - 6:30 PM CST
May 10, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have the Electrolux Pronto 2-in-1 Vacuum and need a new charger Where can I get one as soon as possible Thank you
This is a good URL for your part
http://www.ereplacementparts.com/electrolux-parts-c-109672.html?osCsid=ip7otskdiu58aaud0fgvvv1f57
Oct 12, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux 2-in-1 Pronto does not hold charge, I believe it's a battery problem. How do I get then replace the battery, since it is located in the hand vac part of the vacumn?
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
Jun 28, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I need a new battery where can i get a low
The batteries inside the small hand held are NOT consumer replaceable. They are all soldered in place. If you are a handy with a soldering iron, you can replace the batteries yourself. I did and my Pronto 2-1 runs like new. I had it for about a year then it gradually lost its holding charge. I would only get about 2 minutes before it stopped.
Battery Replacement. First you will need new batteries. The batteries for the Pronto 2-1 are called NiMh 4/5 Sub C 2000mAh w/ TABS and can be purchased at Batteryjunction.com. You will need 8 of them. I paid a total of about $30 shipped. Next. Remove the 4 small screws holding the unit together. Once you have it apart you can get an idea of what is ahead. It took me about 45 minutes to cut out the old batteries and replace with new ones. Here are some helpful tricks. Use a knife to cut off the tab jacket about ¼ inch from the ends on all of the new batteries. Use a pair of needle nose pliers and tear off the battery tabs right off the OLD battery bodies. Replace the batteries ONE AT A TIME except for the group of 4 in the handle. The goal here is to solder the new battery tabs to the OLD battery tabs. This is much easier soldering tabs together than stripping and soldering the wires. REPLACE the batteries exactly how you see them. Add electrical tape where appropriate. Be careful when packaging the batteries back in place. I mentioned replace the batteries one at a time because this will allow you to verify your soldering. Press the on button and you should get the blower going. If not, you have a bad solder joint. Anyway, good luck. Jeff
Jul 20, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux Pronto 2-in-1: Looking for a part
There is no replacement for the dust container in these units. You would have to get an entire handvac which costs more then a full unit.
Jan 02, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne Logo
42 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
