Question about Roper RAS8445KQ Top Load Washer
Wont change cycles - Roper RAS8445KQ Top Load Washer
  • 472 Answers
If it is not going through any of the cycles then you most likely have a bad timer assembly... if it fills with water but then won't wash,spin or drain even when you put it to the setting on timer...check your lid switch most likely bad. you can unplug unit and by-pass to test. take a jumper wire and jump the two terminals of the plug out usually the two outside terminals plug back in and see if it works then if so you know you got a bad lid switch... they put these on as a safety feature so when you raise the lid it kills the operation of unit during any moving parts
Posted on Jan 02, 2011
The timer that changes the cycle wont change from wash to rinse to spin i have been doing it manualy by pushing in nob and turing myself
If a mechanical timer is fitted more than likely the timer motor is burnt out. This part is usually not available on it's own & you will need to replace the timer.
Mar 16, 2015 | Washing Machines
How can I fix the LED monitor so the cycles do not change mid cycle?
It sounds like a control problem. I assume it is electronic, and if so try another control board but be sure you can return it if it does not solve your problem.
Jan 11, 2015 | Haier Hlp23e Portable Top-load Washer
It wont change cycles.
IF IT'S OVERFILLING, YOU NEED TO CHECK THE VACUUM HOSE(CLEAR OR BLACK HOSE FROM TUB TO PRESSURE SWITCH). IF IT'S CLEAR, BLOW IN THE HOSE, YOU SHOULD HEAR A CLICK ON THE PRESSURE SWITCH, IF NO CLICK, YOU HAVE A BAD SWITCH.
Jan 16, 2010 | Maytag Washing Machines
When i turn my dishwasher on it runs it wont change cycles and wont wash stays in the same cycle
This sounds like a bad timer.
It could also be a defective thermostat. This problem will become apparent with the water heat option selected. Check by running the dishwasher with this option de-selected and see if it proceeds normally through the cycle.
Hope this helps.
Sep 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Washer stopped and wont turn off
Unplug the appliance from power, or trip the circuit breaker and cut power to the appliance for about five minutes.
While appliance is unplugged check that the drain hose is not kinked and empty water from inside the machine.
Let me know if you still have the problem when you connect the appliance back.
If the appliance does not start back, then there is a faulty part, in that case give me the model number as printed on service tag and tell me when the appliance had been purchased, also tell me the country of purchase.
Many thanks.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Feb 04, 2008 | Hotpoint WMA30 Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
