Question about Ubi Soft Saddle Up with Pippa Funnell for Windows
In the game saddle up with Pippa funnell for PC when i brush my horse the meter goes all the way up but the light doesn't flash and there isn't anymore dust on the horse i tried uninstalling the game and reinstalling it to see if it was a glitch or something but the brushing still doesn't work and i cant continue the game. Also the CD isn't damaged at all either and every time i restart a new game it picks the same two colored horses i think thats also a problem please help!
3 Suggested Answers
SOURCE: In the game saddle up with Pippa funnell for PC
i have the brushing problem too nothing works on any of my three horse maybe its just the selections you make? and its on a certain game path that it happens? cause i just started a new game and installed it after a long time and it didnt happen last time.... maybe when you are offered stuff choose something you didn't choose last time. thts what im about to try.... hope it works for the both of us!
Posted on Aug 16, 2011
I figured it out! I had the exact same problem! Brush the UPPER part of the body first, THEN brush the legs. It worked when I had the same problem.
Posted on Jul 04, 2012
Tip
I have the Kenmore version of this product and the same thing happened. My...
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and embedding it in a block of ice, as well as puddling-up on the bottom of the freezer and eventually blocking the door from closing properly. Because the water seemed to be covering a wider area than you would expect from a blocked defroster drain I didn't believe that my problem was covered by the other FixYa recomendations -and it turned out I was right.
The problem turned out to be that the "funnel" that the water flows through to fill up the ice tray was blocked by a solid piece of ice. When the icemaker would call for more water it would flow down the clear tube (with the open slots on the top) hit the ice and spray/overflow in to the freezer compartment.
The solution was obviously to pop this ice out, but that did require me to remove the icemaker from the wall of the freezer compartment. To do this you
  • remove one screw from the bracket on the bottom of the icemaker
  • Slide the icemaker up and slip it off of the two screws with rubber grommets on them.
By the time I got to that stage I had already removed the basket from the main drawer and removed the pull out tray/basket from the drawer pulls (by simply lifting the plastic tab on the right side and lowering the plastic tab on teh left side). I am not sure if you can remove the icemaker without this step, but I believe so.
Also, if you want to entirely remove the icemaker from the freezer there is only one plug with wiring to undo. As I mentioned above, the water hose doesn't not connect to the icemaker, it ends above the "funnel" and the water drops in. So removal is much simpler than you might expect.
As for the cause of the ice block, I am not sure but I believe it was either because the ice maker made too much ise one time and some cubes could not pop out. When additional water entered the funnel it didn't flow in to the ice tray, backed up, and froze in the funnel. The other thought is that when the door was not closed properly while our grandparents were visiting, the ice melted and subsequently re-froze causing the problem.
on Oct 05, 2009 | LG LFD25860
If I have Windows Vista..will the game "Saddle up with Pippa Funnell" work?
No. It only works with XP and older Windows OS versions. (Both the company site and the Microsoft Compatibility Center give this response.) I don't think even the Run as Compatible option will help.
I wish that I could be of more help.
Jun 14, 2010 | Ubi Soft Saddle Up with Pippa Funnell for...
How do we get the bridle and the saddle on the horse.
your horse has to be fully grown. Pick up the sadlle bridle and sadle pad put them in your inventory go over to the horse click on each item and then click on your horse
May 21, 2010 | ValuSoft Let's Ride Friends Forever for PC...
Not sure about buying this saddle
The saddle itself is quite well made and should last a good while with proper care and maintenance. However, three things concern me and one is that it is a saddle you are used to using. If you are used to the support of a western saddle and move to a close contact, it may be very uncomfortale until you get used to it. The second is that the horse you use it on is used to being under a close contact saddle. The third and most important is that you indicate that you ride ' all different horses and ponies '. You do not clarify if you are wishing to use one saddle on all. I do hope not as saddles are not one size fits all. The saddle must be fitted to your 'seat' and the tree width and rise must properly fit the size and shape of the horses back. If you are unfamiliar with this, I suggest you learn how to fit a saddle before buying anything.
Jan 01, 2010 | Weatherbeeta Kincade Close Contact Saddle
Lagging views and change of enviroment colours
If you are shure you have the right graphics card, go to the your display settings, on the Control Pannel, and try to adjust the screen resolution, and the color quality.
Hope this helps.
Levi_xx
Jul 11, 2009 | Video Game Consoles & Games
Not sure how to save during game play on pippa funnell 2 nintendo
Is there an options menu on the game? The save button is usually in there.
Jan 10, 2009 | Nintendo DS Lite Console
Ubi Soft Saddle Up with Pippa Funnell for Windows Logo
79 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
Hanzu
dante
Tom Chichester
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
