Question about Epson Office Equipment & Supplies
Black ink is not working even after replacing with a new cartridge. It printed 1 or two pages and then quit. I tried another cartridge and it did the same. colors work. I cleaned print heads. Is there a way to clean the black one independently?
    Problem Solver:
  • 14 Answers
You must diassemble the unit. and check the head of your printer. use alcohol 70% and hot water to clean that head. maybe it cause the ink stock of your printer head you need to clean it manually.. to you assemble the printer see your manual..
Posted on Jan 02, 2011
New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
Replace the Ink service station.
Sep 23, 2010 | Brother HL 2140 Laser Printer
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Will only print color even though there is black ink left...If I set it to print with black ink, blank pages come out. I know there is black ink left so why doesnt it print when I set it to print black??
Hi Mel,
It sounds like your print head could be blocked or the black cartridge has gummed up.
Have you tried taking the black ink out, put a rag over the hole where it would normally come out (carefully as it could go all over you) and gently shake the cartridge, then replace it back in to your printer.
Try printing in black and see if it helps, if not then i would be quite sure that its the print head, if this is the case then the only way would be to contact HP as I'm not sure if its possible to remove the print head or even if HP supply replacements.
I hope this helps a little
Mike
Sep 26, 2009 | HP DeskJet D2560 InkJet Printer
Printer replaced with black cartridge, and doesnt print
Either the print head for black is faulty, or the wiring to the black print head on carriage are broken. Try also cleaning the metal sensor to the black cartridge inside the ink carriage.
Apr 14, 2009 | HP Officejet J5780 All-In-One InkJet...
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
Cannot get yellow to print
I had the same problem with the yellow cartridge. Yellow quit printing, put in a new yellow and still would not print yellow. I had a help file, don't know where I got it, but it suggested replacing the black ink cartridge also, even though the black wasn't low yet. Replaced the black, ran a few nozzle cleans and everything worked fine. Don't know why. Try it
Mar 03, 2007 | Epson Stylus CX6600 All-In-One InkJet...
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
