Question about Brother Sewing Machines
I have a Brother 70 stitch computerised sewing machine. I have managed to fill a plastic bobbin with shirring elastic by not using the little tension knob, only the hook section of it on top of the machine. I cannot, however, get the filled bobbin to work at all on the fabric. It either breaks or gets tangled with the coloured cotton. Any hints?
  • 4 Answers
Apparently Brother machines are notorious for not shirring with elastic thread. I use a cs6000i and have had nothing but trouble untill now. Self wind your bobbin with the elastic thread, not too tight, not too loose. Don't use the bobbin winder on the machine-it will pull the elastic thread too tight. Remember to use regular thread for your top thread. Read/watch the two tutorials and you'll be on your way! I tried everything I could think of and these two solutions were the only ones that worked for me. Good luck and hang in there, you'll get it! http://www.sewmamasew.com/forum/index.php?topic=3352.0 http://www.youtube.com/watch?v=RvXzoFzvVF
Posted on Feb 02, 2011
  • exit18
    exit18 Feb 03, 2011
    super sorry, the sewmamasew link isn't correct, the correct link is:http://gigglesmum-creativeheart.blogspot...
    watch the youtube one as well, it's quite helpful.
    Genius:
  • 1,788 Answers
You should not have both, bobbin and top thread filled with elastic, it may screw up your timing. And you are talking major expense to fix. Use regular thread in your bobbin.
Posted on Jan 03, 2011
  • exit18
    exit18 Feb 02, 2011
    http://www.sewmamasew.com/forum/index.ph... http://www.youtube.com/watch?v=RvXzoFzvV...
My sewing machine don't want to work the elastic tread that you use for smocking. I put it on the bobbin. Also, were can I download a free service/ repair manual?
To seek a manual, search the internet for:
Manufacturer + Model + the word "Manual"
Be sure you hand-wind the bobbin with the elastic thread. You may also need to loosen the bobbin tension a bit if the elastic thread is stretching too much while stitching.
Shirring with Elastic Thread
Pretty Ditty Shirring tutorial
How to use elastic thread How to sew with Elastic thread
Tutorial shirring with elastic thread Made By Rae
Dec 02, 2015 | Sewing Machines
CANNOT Figure Out Shirring on... Brother LS-500
I was just reading in the manual for my antique Montgomery Ward Model 30. It described shirring using a ruffle foot. If we can extrapolate from this info you may be able to do shirring with yours. You'll need similar material scraps to practice.
It describes a "shirring plate" that essentially goes over the feed dog area and eliminates their pulling the fabric through. So to emulate this you'll need to lower the feed dogs. Look for a slide type switch either on the front or back of the machine near the needle area.
Attach your ruffler foot. The instructions say to remove the separator blade... that's the very bottom part of the attachment. On mine there's a screw that allows you to take that part off which only leaves the blade that tucks the fabric to make the ruffle. (hopefully modern machines have this ability) Make sure you place your screw and blade in a safe place. (I like to use masking tape... and tape it to a safe place)
Place the material between the feed dog area and the ruffler blade. Longer stitches mean bigger and more loose ruffles. So lets start with big ruffles.... set your stitch really long. Set your ruffler setting for the desired type of ruffle or Plait. Shirring is done with a single stitch plait or "gathering"
Ok here is where it gets a bit confusing because modern seamstresses don't have the variety of threads we used to (or can afford anyway) It says. "Thread bobbin with mercerized DMC floss No.3 keeping the bobbin tension loose, long stitches and thread top with stitching silk that contrasts strongly with the color of the DMC sot that the stitch of the bobbin thread will stand out clearly as a trim" It also suggests the use of the quilting guide to make your stitch rows evenly spaced.
So practice this technique on some scrap or similar materials. Good luck. ;)
Sep 06, 2012 | Brother Sewing Machines
I am trying to shir using elastic thread in my bobbin but my fabric will not shir & my elastic there jams causing me to start all over. I have studied many tutorials. It seems I need to tighten the...
Have you wound the bobbin with the shiring under tension? you need the shirring elastic to be stretched somewhat as it goes onto the bobbin so that when stitched out, it relaxes and pulls the fabric up.
And yes, usually you need to tighten up the bobbin tension also to stretch the elastic some more.
The Ellure has a horizonal drop in bobbin so you will need to access this to adjust the tension. This may require unscrewing the two screws holding down the needle plate (metal flat plate you sew over). Take this off and now you'll see the bobbin holder area clearly. Look where the tension spring is, the little groove you pull the thread into when threading up. Is there a small dial just near this, about 7mm across? it will have a groove in the top and hopefully a + and - marking.
IMPORTANT: carefully make a note of where it is set now. Take a picture or write a little diagram down so you can get it back to normal setting. Use your little accessory screwdriver and carefully turn it one click to +, then test sew. YOu may need to turn it up 3 clicks to get the elastic stretched enough. Just make sure you know where to set the dial back to when you are done.
Also, remember you won't be able to shir heavy fabric, just light weight cottons work best.
I find that stitching lots of straight lines of shirring like you see tube bodice sundresses made in ready to wear is very hard, factories will have a machine that sews 20 rows at once. And getting enough gathers is trial and error with a domestic sewing machine.
Here's how I do it. Turn down top selvage edge of the fabric width you want to gather, turn down about 10mm and straight stitch around. Now on the wrong side with a sewing marker pen rule lines down from here across the fabric width spaced 1 cm apart. Now lie shirring elastic on these lines and stitch over it with a narrow zig zag stitch making sure not to catch the elastic with the needle. Start each sitching seam one cm from the raw edge of the fabric and finish the seam the same way.
Now I pull the elastic up from each side pulling all of them evenly until I"ve got it gathered enough. Now place right sides together and stitch the fabric into a tube catching the elastic ends in and securing them.
I hope this helps you out.
Jul 19, 2011 | Baby Lock Ellure
I am trying to do shirring with elastic thread on 100% cotton fabric, but it is not working. The result is very poor. I hand wound the bobbin with elastic thread but unfortunatly is doesn't stretch out...
I hand wind the bobbin but use regular thread for my top thread and set my machine with the longest stitch length. I put my tension on 3, my friend uses 4 but I guess it depends on your machine.
Jan 28, 2011 | Singer Sewing Machines
My machine is not shirring. I hand wind the elastic on the bobbin properly(in fact 4 different ways from no tension to medium tension on the elastic). I have it on a straight stitch and selected 4 as the...
you are doing it wrong, thread the machine top and bottom as normal, shirring elastic on your lap, select a small zig zag or pattern, sew and as you sew pull the shirring elastic taught, mif you wind the shirring elastic on the bobbin you will mess the tensions up.
Apr 22, 2010 | Brother CS-100-T Computerized Sewing...
When sewing with shirring elastic on bobbin the material does not gather the machine sews great any other time model no is bm-2600
my friend and i sat at the machine to see what was happening
the 1st thing wrong the plastic bobbin was the wrong size and the bobbin was not threading through the tension spring as the elastic was to thick
Jan 05, 2010 | Brother LS2020 Sewing Machine
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Bernina Bernette 65 sewing machine is not sewing properly. Thread is bunching up from the bobbin. I have re-thread the bobbin and the machine and read the manual. Ideas?
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Aug 20, 2008 | Bernina Bernette 75
I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Aug 07, 2008 | Sewing Machines
Sewing Machines Logo
289 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
