Question about Kitchen Ranges
I have a ~1977 vintage built-in Gaffers and Sattler double electric oven. Top oven doesn't heat up in "bake" mode (broiler element works fine). Indicator light(the one outside the oven that shows when the element is actually energized and heating because the thermostat isn't happy yet)lights up and stays lit, but element doesn't warm up at all. I thought for sure the element was bad, but on close inspection it has no visible signs of failure. I guess I can pull out the element and do a continuity and resistance check with my multi-meter (don't know what the specific resistance value should be). It dawned on me that it might be the temperature sensor, and not the heating element. It doesn't look like it can be removed without pulling the whole unit out of the wall, plus I'm not sure how to troubleshoot it, anyway, short of just trial and error R&R. Guess it could also be the switch--does the fact that the light comes on rule in or out any of these three?
  • 5,911 Answers
I'm not sure how your range is configured, because I've never heard of the Brand name before. However, most electric ranges have an Electronic Oven Control (EOC) Board that controls all the oven functions. There's usually a separate relay on the board for Bake and Broil. The indicator light could be an indication that the relay is working, but I'm not sure.
As far as the element is concerned, it does not have to look bad in order to have a problem. You should be able to access the terminals of the element in question by removing the back panel of the range. Make sure you UNPLUG the range before attempting any repairs. There is live voltage present a the terminals even with the range turned off. That's why it is important to either unplug or turn off the main breaker. A resistance check at the terminals should indicate a fairly low resistance. This reading varies with different models. Again, I'm not sure what yours would be. This can range from a few ohms to a few hundred ohms depending on the type material used in the manufacturing of the element. Your best bet is the use the continuity function on your meter to see if the element has the proper continuity. If it doesn't, replace it.
I have a couple of links you can try to assist you as well. The first link describes how to replace elements in MOST electric ranges:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
The second link explains how to test and/or replace the oven temperature probe (sensor):
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
I hope some of this is helpful to you.
Posted on Jul 09, 2008
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Dec 22, 2009 | Ovens
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
279 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
