Question about Aluratek AHDVC03F CINECAM HD 1080p DV Camcorder
I cant get the flash light to work on my aluratec AHDVC03F, 1080p cinecam camcorder. I tried pressing up on the 4-way direction button like it says in the manual but it still wont work, I even have it in night mode, not sure if that makes a difference or not. I know the light works because It works for a flash when taking pictures but it wont work as a flash light. the camera doesn't have very good lighting to begin with so I need this for recording in low light and and darkness. please help
  • Aluratek Master
  • 4,406 Answers
For video, you need continuous lighting, not a flash.
Posted on May 27, 2017
3 Suggested Answers
SOURCE: i dont know how to turn on the flashlight on my
I had this problem and Aluratek did a poor job describing this feature in their product. Use the FUNC/SELECTOR (Circle below the record button) and press it up for flashlight, to the sides and down for other options.
Hope that helps.
Posted on Dec 05, 2010
  • 13 Answers
SOURCE: need user manual Aluratek Cinecam HD DV Pocket
http://aluratek.com/media/uploads/AHDVC01F_QSG.pdf
go here.
or
http://aluratek.com/cinecam-high-definition-720p-digital-video-camcorder
Posted on May 06, 2011
Testimonial: "exactly what i was looking for.thank you very much."
How can i set up my direct tv remote to my Haier tv
How to scan for TV codes on your DIRECTV remote
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9-9-1, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
Feb 13, 2013 | Haier HL22XLE2 - HL22XLE2 22 LED-LCD TV -...
I cant get the remote and the t.v. synchronized
Try these methods.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 04, 2012 | Televison & Video
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    I dont know how to turn on the flashlight on my aluralek hd 1080p cinecam?
    Hope that helps.
    Oct 30, 2010 | Aluratek AHDVC03F CINECAM HD 1080p DV...
    Ive just purchased a vivitar 830xhd camcorder and
    The flash on the camcorder only works while taking still pictures, not for videos.
    For still pictures, pressing the Flash button on the lower-left corner of the display gives you three options: Auto, On, and Off.
    For videos, if you want more light, you're going to have to look elsewhere. Any good camera store can show you a selction of lights.
    Feb 23, 2010 | Cameras
    On off light blinkinking from green to red and I
    Canon IP3000 INK counter reset
    Can gave it a go may work
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not,
    press the Power button once more.
    8. Your printer should respond as normal..
    Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
    Printed pages come out blank
    Hello please try this
    1. Turn off printer
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    Jun 01, 2009 | Canon BubbleJet i550 InkJet Printer
    S9000 canon printer ink tank full
    Hi
    Try this see if work for you.
    may work
    Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
    1. Turn off printer
    Nov 02, 2008 | Canon i950 InkJet Photo Printer
    Aluratek AHDVC03F CINECAM HD 1080p DV Camcorder Logo
    75 people viewed this question
    Top Aluratek Video Cameras Experts
    Are you an Aluratek Video Camera Expert? Answer questions, earn points and help others
