Question about Maytag Washing Machines
Whenever I use the quick wash I get an error E3 what is the problem
    Top Expert:
  • Maytag Master
  • 9,472 Answers
3E == overcurrent detected at the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (presschimeandextra rinsekeys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also go ahead and check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
You will need a multimeter to test the wiring.
Posted on Jan 02, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible.
Refer this site for 60 inch dishwasher and this site for 45 inch ones.
Jan 02, 2013 | Smeg Dishwashers
My haier washing machine with error code E3,what 's the problem?
Can you help me to fix my haire plz it not spin
Nov 11, 2011 | Washing Machines
Washing machine stopped and door opened and says E3. please help. machine is a bosch wae....
The machine identifies and indicates some operational errors through a series of beeps.E3 is also listed in that beep.the meaning of e3 is nothing but it is telling to call the service engineer.This error signal is due to Thermistor open/short.Thanks for your question.
Jun 19, 2011 | Washing Machines
My Kenwood KDW243A built in dishwasher is desplaying what I assume is an error code, E3. What does this mean? The washer is not washing properly.
E3 means the base is full of water. A quick fix is to tilt the machine back for 10 mins or so but you need to find the cause of the leak and repair it
Jun 03, 2010 | Kenwood KDW243A Builtin Dishwasher
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Jun 23, 2008 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
