Question about HP LaserJet 5L Printer
Small pieces of paper are stuck and cant be reached
  • HP Master
  • 4,338 Answers
Paper is probably stuck under the fuser, follow these instructions to remove the fuser:
Fusing Assembly Removal and Replacement
1. Remove rear cover:
a.) Extend input extender assembly
b.) Remove three screws
c.) Separate the rear panel from the main cover, pulling the lower corners away from the printer first. Then,
insert small flathead screwdriver into the openings at the top upper corners releasing two tabs,
remove cover.
2. Remove EP door assembly
a.) Along the left door hinge there is a flex point, firmly press tab inward to release door.
3. Remove main cover
a.) Remove rear cover
b.) Remove EP door
c.) Remove memory cover
d.) Remove two screws from top of printer
e.) Grasp two lower front corners of printer and pull gently outward, lift cover straight up and off
4. Remove fuser
a.) Remove exit roller (unlock white bushings on either end)
b.) Remove right hand cartridge guide (depress one locking tab and slide forward)
c.) Remove two screws from delivery assembly (fuser cover) and remove
d.) Remove two screws from pressure plate, (metal) unlock two retaining tabs and remove
e.) From right side of printer, remove cable guide, and fuser cable from DC controller
f.) From left side of fuser, remove thermistor cable (white) and remove fuser
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Posted on Jan 02, 2011
My FS-4000DN printer says paper jam, but I cannot see one, not even a little scrap of paper, how to fix
In my experience with copiers and printers,small bits of paper can get stuck in areas that you cannot reach easily. It happened to me when I was working on an hp. printer. I had to remove the manual feed assy. in order to remove a small piece of paper that was crammed in a small space around a sensor. I removed it,re-assembled it and printer worked fine after that. In some cases the sensors go bad but most of the time it's paper. Hope this helps.
Sep 18, 2017 | PRINTER Office Equipment & Supplies
Canon injet says I have a paper jam. but I don't.
the solution of dgartner1 was helpful... after pushing a piece of paper several times, we discovered that there was a dead cockroach stuck inside. we had a hard time getting it since the passage/opening is very small and hard to reach.. thanks now the printer is working properly
Jan 04, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Cannot get printer to work keeps saying paper jam but I cleaned it out don't see any jam will not print? i inplugged it also still does not work ?
This happens if the jammed paper tears during removal and a small piece is stuck in the jam sensor or the jam bent or broke the jam sensor. Can you remove the paper tray or open any doors on the back to see any pieces left behind? A visual inspection perhaps with a flashlight may show something in there. The paper path is very short so you should be able to see something. If you can't reach it, you can try inserting a few sheets of paper or something thin and flexible to push it out.
Feb 03, 2011 | Brother MFC 240C All-In-One InkJet Printer
Tiny piece of paper is stuck and i cant get it out. it is real small and ive tried alot of options.
Have you tried some canned air? That should get it out and blow out any paper dust as well. Yeah, do it outside. LOL.
Oct 19, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Where can I take my Stylus Photo RX500 for repair? The paper feeder eats the paper on one side.
you probably have a tiny tiny piece jammed in the roller on that side. sometimes it gets stuck inside and you cant see it. take it apart and use tweezers to pull it out. usually its a small piece similiar to the leftover junk you get when you rip out a page from a ring notebook.
Sep 03, 2009 | Office Equipment & Supplies
Cant connect to the batterie bolts dont reach
... put a small piece of folded paper under each nut to raise them up then the bolts will reach the nut use the bolts that come with the battery
Mar 04, 2009 | 2005 Suzuki SV 650 S
Misfeed
there is most likely a small piece of paper on a sensor/
remove paper tray and look inside, is there paper behind the tray? look at the tires are they bald and sniny? replace. Look at the tires and see if there is any scrap of paper there.
open right door and look down towards the paper tray, do you see any pieces of paper? there is a small black lever there, it's the sensor is it stuck?
look into the fuser (where it gets hot) ,you may have to remove it the paper sometimes gets crumbled like an accordion there, htere is also a small black lever there see any paper is it stuck?
Sep 15, 2008 | Sharp AL 1631 Copier
Showing paper jam but no paper in machine help!!!!
please confirm that all paper detecting switches are in normal position and can move freely and no small pieces of torn paper inside-clean all switches with dry cloths or brush.-reset your copier off-on-operation.
Jul 22, 2008 | Office Equipment & Supplies
HP LaserJet 5L Printer Logo
412 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
