Question about Cameras
Digital Camera memory card
Will a secure digital memory card work in my Olypus D460 digital camera that I purchased in 2000?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey meyer1966,
Unfortunately this camera should only accept SmartMedia memory cards and a SD memory card should not work with this camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 09, 2008
I have a Samsung S730 digital camera and like it very much. I have a 1GB SD memory card and it works great, but I want to purchase another memory card, but the only SELL 2GB SD cards is that ok to use in...
Hi
The Samsung S730 digital camera will work with 2Gb Secure Digital (SD) cards without an issue. If you want to go with a higher capacity card you can also use 4Gb and 8Gb SDHC cards.
Hope this helps
David
Dec 29, 2010 | Samsung Digimax S730 Digital Camera
MY OLYPUS E-500 SAYS CARD ERROE WHEN I TURN ON MY
Did you try to format the card using the camera's software or your computer?
May 20, 2010 | Olympus EVOLT E-500 Digital Camera
Brought a new memory card and it wont format keep saying error
Hi mr .
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 05, 2010 | Olympus Camedia C-350 Digital Camera
    How to delete pictures from a d-460
    Judging by your explanation, the photos are on your sd digital memory card rather than the internal memory.
    Since you are unable to delete just those 15, it sounds like you might have accidentally enabled the "protect" function.
    Get out your manual (or download a new one) and read about how to protect/unprotect photos, and also read about how to format your card in camera - something you should do on a VERY regular basis for the health of your memory card.
    While you have the book out, read ALL of it - twice! You'll be amazed how much you'll learn.
    May 01, 2010 | Olympus Camedia C-350 Digital Camera
    Am looking at a second hand camera canon a410 and the seller says you need a hd card what is this?
    I am sure he is referring to an SD (Secure Digital) card. This is a standard memory card for most digital cameras. So after purchasing the camera, you have to buy an SD card to record images.
    Dec 13, 2009 | Canon PowerShot A410 Digital Camera
    My camera keeps saying write protect when i turn it on. How do I solve it. My memory card is Olypus XD.
    Remove the memory card and look for a near-microscopic slide switch along the edge of the board. If you don't find one, it may have a tab-type lock that has been activated.
    If the card is not equipped with either one, it is probably dead.
    Aug 27, 2009 | Olympus Stylus 770 SW Digital Camera
    "Memory Card Error,""Card Locked"
    Don't Panic there should be no trouble with this sale, The Canon Powershot takes SD memory cards which stands for Secure Digital, Secure in the fact that the memory cards have a tiny switch on the side of them that can be locked so that there cannot be anythong written or deleted from the card.
    This is probably what has happened to this camera, nothing to do with the actual camera but with the SD memory Card.  To fix it just switch the tiny switch on the side of the Sd memory card to the unlock position and everything should work fine!!
    Cheers
    Emmanuel
    P.S Can you post the link to the ebay auction as this would be very helpful.
    Sep 11, 2008 | Canon PowerShot S3 IS Digital Camera
    Memory cards
    You may be able to store up to 110 images if you use the camera in its lowest resolution mode. In high resolution, you may get only 24 shots. We wish we could tell you precisely, but it depends on the exact size of the file created by a given camera, as well as the resolution that you select. Keep in mind that Secure Digital, CompactFlash, and SmartMedia memory cards are competing products and are not interchangeable. You'll find a few cameras that are compatible with more than one brand, but generally when you buy a digital camera today, you'll be making a commitment to work with one type of memory card. Use the attached chart to determine the average number of photos that Secure Digital memory cards can store (compatible with most HP digital cameras)
    Sep 08, 2005 | HP Photosmart 120 Digital Camera
    Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
    The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Cameras Logo
    59 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
