Question about Kenmore Dishwashers
HOW TO CLEAN OUT THE FILTER ON KENMORE PORTABLE DISHWASHER MODEL 664
  • 530 Answers
SOURCE: Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
Posted on May 29, 2009
garing
  • 998 Answers
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Posted on Aug 11, 2009
garing
  • 998 Answers
SOURCE: Model #17829 portable kenmore dishwasher doesn't run
check the cord
thumbs up
Posted on Aug 17, 2009
SOURCE: Kenmore ULTRA WASH Portable Dishwasher
i have had my dishwasher for 10 years never a single problem , i connected it turned it on , it filled with water then it just shut down down won;t do a thing. any ideas?
Posted on Sep 12, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore dishwasher model #665.17034401 --- Clean light blinks
The blinking clean light is an interruption in the dishwasher program that indicates a component malfunction, or it can be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
Posted on May 07, 2010
Testimonial: "Quick response, thorough and very helpful. Thanks, Al"
I have a model#110774191 portable dishwasher(kenmore) it is not cleaning anything properly on the top rack. The water pressure seems good I have tried running vinegar through it I also use jet dry, I have...
the upper arm is blocked?and needs taken out and cleaned its very easy to do just pull out the top drawer and the arm will litterly pull off give it a good clean and it should be ok,also make sure the filter at the bottom is clean.adrian,,,,,,,,,,
Aug 17, 2010 | Kenmore 17248 Silver Steel Free-Standing...
Dishwasher not cleaning - want to clean drain
We have a Kenmore 665.17702k600 Portable dishwasher with a similar problem. What we did was pop off the drain cover (turns out the one screw wasn't doing anything and just pushed down into the unit when screwdriver was applied). We popped it off by shimmying a screwdriver under the panel, and applying torque on the long end. It just popped right off. Then there was this nasty stale water, and not much obvious debri. We used a wet vac to slurp all that up. So that's the solution we took -- haven't tried it yet, so not sure if it will actually fix the problem...
Nov 02, 2009 | Kenmore Dishwashers
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
THERE IS A PLASTIC COVER GRATE IN THE BOTTOM OF THE DISHWASHER TAKES A 1/4 INCH NUT DRIVER TO REMOVE IT, TAKE IT OFF CLEAN OT THE DEBRIS AND FLUSH WITH A BUCKET OF WATER, THIS IS SUPPOSED TO BE THE FILTER, IF ANYTHING IS IN THERE YOU WOULD BE ABLE TO SEE IT, I HAVE FOUND STRAWS AND KNIVES IN SOME DISHWASHERS, HOW THEY GET IN THER IS A MISTORY BUT THEY DO
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Dishwashers Logo
380 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
