Question about Daewoo Washing Machines
Water is not flowing into the machine after the start button is press.
  • 1,998 Answers
Check the hoses and check the water valve if there is no water going past the water valve you most likely need a new water valve. Any further questions message me back and please remember when our chat is concluded to rank how this opinion has helped we try to get 4 thumbs up each time thanks again Rick
Posted on Jan 02, 2011
Water does not flow into the machine once its started
Silly question: Did you shut off the water supply to clean it out and then not turn it back on?
Feb 17, 2014 | Select Brands Washing Machines
Machine set on programme, start button pressed, water flows in but but drum does not turn (motor not starting) with the result clothes unwashed!
Once the inlet valve opens and thewater flows into the drum then there is a water level sensor- a pressure sensor switch- that works to activate according to the quantity of clothes you have chosen. This switch must work and teh program controller will then switch on the motor. so the fault can be related to the program controller or to the water level sensor.
Mar 31, 2011 | Bosch Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
May 30, 2010 | Fisher and Paykel Washing Machines
Kenmore Elite smartwash QuietPak9 F H error code
Press the Pause/Cancel button twice to clear the display then check if water is introduced into the machine. Drain the water from the machine by selecting Drain and Spin then pressing the Start button for one second. Empty the machine after the water is completely drained.
Start a new cycle with Hot/Cold water temperature and check how long before the error code appears after the cycle is started. When the code appears, press the Pause/Cancel button to clear the display then check again if water is introduced into the machine.
The pressure switch is not tripping and must be replaced if the error code appears about 8 minutes after the cycle is started and about 40 liters of water is introduced into the machine.
The flow meter is not working if the error code appears less than a minute after the cycle is started and about 3 liters of water is introduced into the machine.
The valve solenoids may not be working or the levers are stuck if the error code appears less than a minute after the cycle is started and no water is introduced into the machine.
Let us know which case above is observed for specific troubleshooting and repair guide.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Gaggia titanium espresso ventilate is on the screen.I press button 26,nothing happens
Hi
When you push the water button, then open the steam knob. This will allow water to flow. If you don't get water to flow check the water tank and make sure that it is down on the machine completely. The other thing that will not cause water to flow is a restriction in the flow meter.
Nov 02, 2009 | Gaggia Titanium Espresso Machine
Water doesn't come out from showerhead once the button is pressed - can hear the water pump going, the top of machine is warm so boiler is functioning.
Does water flow without the portafilter in place, if yes then check grind, if no then remove screw,filter and diffuser and press brew button, if water flows clean filter, if no water then the micro jet in the group head is blocked or the solenoid is clogged.
Oct 06, 2009 | Rancilio Epoca ST-1 Espresso Machine
E1 error code
Fault is 1E- this indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, but in my experience it is much more likely to be flow meter
Aug 05, 2009 | LG Dishwashers
I have a Gaggia Evolution expresso maker about 8 years old. When button is pressed to start motor it just hums and no hot water comes out. The motor only runs if I open the steam outlet
Try this, under the grouphead, there is a screw and screen, remove those, and check screen to see if it is clogged, when screen is removed press button to brew, if water flows freely then problem is at the screen, if no water flows, then it is on the inside of the machine. You will have to run a descale cycle to clear out machine. Check the folling pic for the screen location.2722dbe.jpg
Jun 27, 2009 | Gaggia Syncrony Compact Coffee...
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Washing Machines Logo
65 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
