Question about DeLonghi BAR 140 Espresso Machine
I have a model (Delonghi BAR 140 L'Espresso) that we never used, but I would like to find parts to it, because I'm missing the handle that contains the basket for the grounds. How would I go about doing that? I can't find anything on their website.
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
  • 1894 Answers
SOURCE: Describe your DeLonghi BAR 32 Espresso
i think your thermostat is dead
have u check it out?
Posted on May 15, 2008
  • 3 Answers
SOURCE: Problems with handle alignment
I DON'T THINK YOU ARE GETTING A GOOD SEAL ON THE PORTAFILTER . YOU HAVE TO MAKE SURE THERE IS NO COFFEE AROUND THE EDGES AND EVRYTIME YOU ARE DONE BREWING RUN SOME WATER INTO A CUP WITHOUT THE PORTAFILTER IN PLACE .
Posted on Mar 17, 2009
SOURCE: Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Posted on May 05, 2009
  • 1089 Answers
SOURCE: Leaks under pressure
Hi
Your brew head gasket is leaking and needs to be replaced. remove everything and turn the machine on its top. Look ate the brew head inside there is a black gasket and it should be clean and flat. If its cut or curled it needs to be replaced. Not cleaning the brew head will cause this gasket to be cut and after a while it will curl and not seal.
Posted on May 21, 2009
May 15, 2008 | DeLonghi BAR 32 Espresso Machine
How much coffee to add for 20, 40, 60 cups of coffee in the 60 cup DeLonghi coffee urn?
I like my coffee pretty strong and I use 2/3 cup coffee to 10 cups of water...
You may be able to use 1/2 cup to 10 cups if you don't want it too strong...
You must experiment a bit as different coffees will vary also...
heatman101
Apr 30, 2011 | DeLonghi BAR 140 Espresso Machine
Hi ! I have a Delonghi espresso machin calld
Try this location in Wa.
Action Small Appliance
1500 145 Place SE
Bellevue, WA 98007
Phone: 425-643-9806
Whenever I need parts for deLonghi this is where I call.
Mar 08, 2009 | DeLonghi Coffee Makers & Espresso Machines
Ok light does not turn on
If this is a new unit, you should return it. If you don't have that option, you'll have to open it up and tighten some screws that hold the wires into their respective barrier strips. Delonghi often doesn't tighten them quite enough. The unit will sort of work. The problem may be finding all the screws to remove to get in and that some of them are 'tamper' style. It is also possible that the temp sensors are not fitted right or are defective. Good luck.
Feb 22, 2008 | DeLonghi BAR 140 Espresso Machine
I got used DElonghi bar 32 espresso, but may be missing part of portafilter.
it hard to judge but maybe if you put to mush coffee it hard to lock in place try puttimg less and try it tkanks foe using fixya pierre
Feb 06, 2008 | Coffee Makers & Espresso Machines
Instructions
I beleive these are the instructions you were looking for. http://www.delonghi.co.uk/pdf_files/BAR14.pdf
If not the correct model, please post back and I'll do my best to help you further. I hope this helps.
Nov 29, 2007 | DeLonghi BAR 140 Espresso Machine
Espresso
the filter has a little indent that must be placed correctly, if you put the filter in the holder and then rotate the filter you will feel it click into place when it is in the right position ( there is a gap for the indent at the front of the holder)
Oct 30, 2007 | DeLonghi BAR 140 Espresso Machine
DeLonghi BAR 140 Espresso Machine Logo
131 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
