Question about Microwave Ovens
My maytag microwave doesn't cook and makes this loud noise while it's running. Cannot figure out why?
  • 472 Answers
If the display and time counts down on unt but not heating the food most likely you have a bad magnetron on unit.... the noise you are hearing most likely is the magnetron trying to kick in but the tube is bad... honestly unless you are a servicer or in the field these things often cost almost as much to repair as purchasing a new one... we work on them quite often and after explaining its going to cost around 150.00 to repair the customer usually chooses to buy a new one... good luck to you
Posted on Jan 02, 2011
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 18, 2012 | Microwave Ovens
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Oct 15, 2012 | Microwave Ovens
Our Whirlpool Microwave Oven makes a loud winding noise and doesn't heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 01, 2011 | Whirlpool MH6150XLS Microwave Oven
Doesn't heat. makes a loud buzzing noise when turned on. all other features work. could be from steam getting into it from cooking. is this possible?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Apr 16, 2011 | Frigidaire Microwave Ovens
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Makes loud noise but no cooking power
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Maytag MMV5208W Microwave Oven
Unit doesn't heat and makes loud buzzing noise
heatman101
Sep 24, 2010 | Maytag MMV4205 Microwave Oven
MMV5100AAB Over the Range 1500 watts 3amps -turntable does not turn -does not heat -light works- unit makes loud running noise but will not turn off -must open door or unplug to turn it off. Never any...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Maytag Microwave Ovens
Runs for 20 seconds and trips breaker. making a loud noise when running
heatman101
Sep 07, 2010 | Maytag MMV4205 Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
