42 in panasonic model th-42px25 got audio but no video in audio 1,2 and 3, alredy check all conections and cables.only able to see on componet
  • 4 Answers
SOURCE: ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Posted on Jan 12, 2008
ripleymojica
  • 643 Answers
SOURCE: broken glass - 42 panasonic th c42hd18
usually not very cost effective to replace the front screen. id say around 70% of what you paid for the tv.
Posted on Jun 03, 2009
  • 2318 Answers
SOURCE: my 42 inch sylvania plasma tv does not have a coax
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Posted on Aug 08, 2009
  • 92 Answers
SOURCE: Green vertical line down the screen!
Most likely the failure of the Screen.
If you purchased the product new, and have the receipt Panasonic will repair it FOC from what I understand, at least 3 years, your TV is no where near that old yet.
If you bought it, but don't have the receipt.....
Posted on Sep 07, 2009
SOURCE: PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Posted on Aug 08, 2010
How to connect a PC to a Panasonic TH42PX8B - 42" Widescreen HD
just need the right cable. Look into getting a VGA-HDMI cable
Apr 27, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Th-42px25 red picture, no blue or green
If using component cables check connections at TV or from source. If all rae ok the try source on another tv before getting video input circuit board replaced on tv
Dec 14, 2009 | Panasonic TH-42PX25U/P 42 in. Plasma HDTV
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Which conections for the video and audio cables should be used for the Wii? I put them into the side panel (because of easy access), but can not get the start screen for wii after all is turned on....
once you have matched up the wii audio and video cables to the side panel yellow for video
white and red for audio
thinking you plugged them into one of your tv's av slots
now use your tv remote to switch through your tv's inputs (av1) (av2)
some tv's have a button like that on the tv itself.
Oct 09, 2009 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Volume Problems: Panasonic TH-42PZ700U
please could you send me tips of what the problem of my plasma keeping stuck pixiel panorama LCD Tv model 42LC68T
Mar 29, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic TH-42PD50U 42 in. EDTV Plasma... Problem: video se?al
First, i need to know all your video/audio components and how they connected to your TV?
solutiondoct
Oct 30, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
1 channel only has no audio.
I believe you have cable box right?
Most of the cases if you are getting audio except channel 11,it could be a cable box problem.you can swap the box to another tv and check..
Good luck
Dals123
Oct 07, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No video
try checking what your dvd is set on ie rgb pal or nstc, then check in your tv manual what inputs it accepts
Mar 25, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
TH-42pd25u No Video
I would like to help. Please specify. Are you able to view regular cable tv.?
Mar 10, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
